b18c in 1990 teg, what do i do about MAP, IAB and EVAP
Old Jul 26, 2003 | 08:02 PM
E36 Guy's Avatar
Default b18c in 1990 teg, what do i do about MAP, IAB and EVAP
These all have vacuum lines coming to them on my old motor and the b18c has wires. what do i do. also, where is the IAB, im not sure. thanks !
Old Jul 27, 2003 | 05:34 AM
VTECVillain's Avatar
Default Re: b18c in 1990 teg, what do i do about MAP, IAB and EVAP (b18c3)
The IAB is located directly under and attached to the intake manifold. It's a black plastic canister and the sensor plug faces the driver's side. The MAP sensor is on your firewall and you will need to run the hose from it to the top of the throttle body on the B18C or use the MAP on the B18C throttle body and make your MAP plug reach it. The EVAP I'm not too sure about unless I'm looking directly at the setup.
MoeMoney1984
Jun 14, 2014 04:41 PM
ekcivic2
Jul 6, 2013 10:00 AM
moemoney
Sep 7, 2011 10:33 AM
moemoney
Aug 25, 2011 12:19 AM
