Problem with MAP sensor positioning
Old Mar 7, 2014 | 11:58 PM
MoeMoney1984's Avatar
Post Problem with MAP sensor positioning
Hello everyone,
I swapped a b18c into my 1992 integra gsr . I also bought a new throttle body, but noticed that the MAP sensor for the original b17 is located on the firewall, but the later integras had it on the throttle body directly.
So my problem is that theres a spot to install a MAP sensor on the throttle body that i bought (because the map sensor on the b18c motor is not located on the firewall but the TB itself), but im using the old MAP sensor ( which has a vacuum hose connected to it)
what do I do? do I extend the wires from the one on the firewall ? and what do I do with the hose connected to the MAP sensor on the firewall?
if I lost you, please tell me and ill clarify
thanks everyone
moe
Old Mar 24, 2014 | 11:45 AM
Default Re: Problem with MAP sensor positioning
no one?
Old Mar 24, 2014 | 11:46 PM
nicknack25's Avatar
I ran into this problem when i swapped a b18c1 in my crx as well. What year is your gsr?
What i did was just extend the wires for the map sensor. And i followed a vacuum hose diagram for the rest.
Old Mar 31, 2014 | 12:58 PM
Post Re: Problem with MAP sensor positioning
Thanks for the reply
I have a 92 Acura integra GSR.
- swapped in a b18C1 motor and replaced the intake manifold. I bought a throttle body as an upgrade but i realized that the throttle body has the MAP sensor right on it, while my integra had in on the firewall.
- so i kept my old thottle body ( from the b17 ) on but it idles pretty bad. I want to put my throttle body on but I dont know how to work around it.
what did you do to solve this?
Moe
Old Apr 3, 2014 | 10:11 PM
nicknack25's Avatar
Do you have a map sensor to go on top of your new throttle body? And just lengthen your old map sensor clip to reach the map sensor on the tb.
Old Apr 12, 2014 | 11:27 PM
No i dont , but I've never actually thought of that . What would i do with the hose connected to the MAP sensor tho?
thanks again
Old Apr 13, 2014 | 03:51 AM
kaycee_00's Avatar
Either extend the map wires to reach the new one on the throttle body and cap off the old vacuum hoses, or just run your old one the way it was and leave the throttle body map sensor on but unplugged.
Old Apr 13, 2014 | 01:51 PM
Thanks so much.
Will it do anything if I cap out the vacuum line? I thought maybe it would mess with the pressures.
Do you think the it will be a direct click on to the new MAP sensor? or would i have to do some wiring
( some background info is that I'm using the old b17 wiring harness with my current b18c1 set up. I'll be attaching the clip thats compatible with the b17 MAP sensor to the new MAP sensor. Ive tried to search up if I would have to buy a different clip and do some wiring to make it work, but no luck. I may have to go a buy one and test it)
Thanks again
Old Apr 13, 2014 | 01:56 PM
Did you keep using ur old wiring harness Nick? do u have any error lights on?
whats your wiring setup , right up to the ecu
thanks again
Last edited by MoeMoney1984; Apr 13, 2014 at 01:58 PM. Reason: Adding the name of person I am replying to
Old Apr 13, 2014 | 04:55 PM
nicknack25's Avatar
Yes kept the old wiring harness. And no codes. It's a little messy but you could see how it is
Old Apr 13, 2014 | 05:27 PM
Oh wow ! thanks so much ,,, ill try to do it and ill keep you posted .
Hopefully i can get this throttle body in . Next is I need to find a b- series cable clutch tranny . Tried to see if there are any Canadians to save on shipping, but i couldn't find anything on trannys . lol
Old Apr 14, 2014 | 01:28 PM
kaycee_00's Avatar
Originally Posted by MoeMoney1984
Thanks so much.
Thanks again
You'll be fine blocking them off, as long as they aren't being used by anything anymore. The sensors are generally all the same for b,d, & h series map's so you should be alight using that plug. Just extend it so it reaches, and won't get pulled if the motor moves around from driving. I suggest soldering the wires when you extend them, but if you dont have experience with that use butt connectors and crimp them good.
If you look up info on the multi point conversion for ef's they some times show how to extend the map plug from the firewall to the new one on the throttle body. But its pretty straight forward.
Old Jun 14, 2014 | 04:37 PM
I just got back from Jamaica, I noticed you posted pics. THANKS SO MUCH! that actually helps a lot. Ill do what you said and ill post a pic to show you the progress.
thanks again, and ttys
Old Jun 14, 2014 | 04:41 PM
Thanks so much for the reply. I am gonna try this and get back to you. Thanks Kaycee
moemoney
Sep 7, 2011 10:33 AM
moemoney
Aug 25, 2011 12:19 AM
ALL MOTOR DA
Jun 8, 2006 05:58 PM
SVOboy
Mar 26, 2006 11:48 AM
turbojdm521
Jun 12, 2003 11:29 AM
