***B16 wire question*** Please Help
Puttin JDM B16 in a 91 CRX Si. There are 3 nipples on the back of the motor that are on the left of the oil filter, 2 wires go together for one, and the other is seperate. One wire is black, one wire is yellow with a red stripe, and the 3rd wire is yellow with a green stripe. I am pretty sure I have them in the right spots, but just to be safe can someone check this out for me and make sure that the black wire and the yellow/green go together, and the yellow/red is by itself? I believe these are the same on all motors and not just a B16. Or if you know off the top of your head, the help would be greatly appreciated. Thanx...Later,
From: I told you to wait in the truck in Texas, United States
Sounds like you have it right,yellow with red goes to the single plug
the other yellow with green stripe and the black one goes to the sensor with two prongs..
Any other questions? I had mine in and running for a few months,now its scattered across my shop because the clutch shreaded..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LunSpeedCRX »</TD></TR><TR><TD CLASS="quote">Thanx for the reply. The one with 2 nipples/prongs, does it matter if the black is on the left or right side, and the yellow visa versa? Thanx again...Later,</TD></TR></TABLE>
They can go on either prong, doesnt matter.
-iLLuZioN-B18C1
Oct 25, 2009 05:50 PM
raidacaipo
May 12, 2008 08:07 PM
prada_G
Sep 6, 2006 06:31 AM
red1997civic
Dec 25, 2003 12:50 PM
