Does the oil dummy light usually come on?
Old Jul 26, 2003 | 01:01 AM
sporkcrx's Avatar
Default Does the oil dummy light usually come on?
I just finished swapping in my freshly rebuilt motor, and everything is perfect. The only thing I noticed is that my oil light doesn't come on when I turn the key to the II position, when all of the other dummy lights come on. I extended the wire to a brass tee, where the sensor is. If it's getting no signal shouldn't the light come on anyways? I can't remember if that light always came on before the swap or not.
Old Jul 26, 2003 | 01:14 AM
JonGP4's Avatar
Default Re: Does the oil dummy light usually come on? (sporkcrx)
hrmm? not sure if this applies but i know when my friend did his h22 swap in an accord, he had to change the wires for the oil sending unit and coolent temp? around and that fixed it? whats ur swap? maybe u need to check the wiring for it
Old Jul 26, 2003 | 01:27 AM
sporkcrx's Avatar
Default Re: Does the oil dummy light usually come on? (JonGP4)
It's a stock rebuilt d16a6, same one.
Old Jul 26, 2003 | 09:30 AM
RCautoworks's Avatar
With the engine running and normal oil pressure, the oil pressure switch is open and the oil pressure warning light does not operate. If the oil p.s drops below 4.3 psi the oil switch is closed, current flow threw the oil pressure warning light and the ground, and the oil pressure light goes on. So if the light don't come on at all when you turn the jey just twice I would say the wiring is messed up.
Old Jul 26, 2003 | 02:43 PM
sporkcrx's Avatar
Default Re: Does the oil dummy light usually come on? (90blackcrx)
So yes, it should come on? The only different wiring I did to it was the extension. Does the sensor ground out on the block, but can't ground on the brass maybe?
Old Jul 26, 2003 | 04:28 PM
fourthgenhatchB17's Avatar
YES the light should come on when in the ignition II position. Ever think about checking the oil press dummy bulb to see if its burned out? Switch the bulb with the any of the other dummy light bulbs and if it turns on with the key in the II position, then u found ur problem. Sometimes people overlook the easiest things.
Old Jul 26, 2003 | 08:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote"> Does the sensor ground out on the block, but can't ground on the brass maybe?</TD></TR></TABLE>
Can brass be grounded ? I think it can, because in order for my coolant temp gauge to work I need to ground the brass fitting. So try grounding the brass fitting or just the sensor.
Old Jul 27, 2003 | 01:16 AM
sporkcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">Sometimes people overlook the easiest things.</TD></TR></TABLE>
No I thought of that too, but I just wanted to make sure the light was suppossed to come on first.
Old Jul 27, 2003 | 02:34 AM
matt_sb2000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
Can brass be grounded ? I think it can, because in order for my coolant temp gauge to work I need to ground the brass fitting. So try grounding the brass fitting or just the sensor.</TD></TR></TABLE>
Brass conducts electricity.
Old Jul 27, 2003 | 10:49 AM
Default Re: (sporkcrx)
No I thought of that too, but I just wanted to make sure the light was suppossed to come on first.</TD></TR></TABLE>
Well seeing as how ALL the other dummy lights come on before u start the car...that gives u your answer right there.
Old Jul 27, 2003 | 11:54 AM
sporkcrx's Avatar
slow_low_eddie
Apr 17, 2014 06:01 PM
Kris's turbo
Aug 17, 2011 08:47 AM
Schultzie
Jul 10, 2010 08:58 PM
Dutch_Mofo
Dec 1, 2008 09:58 PM
