White smoke out of the exhaust @ idle...?????
Old Aug 5, 2001 | 12:49 AM
Toda Party's Avatar
Default White smoke out of the exhaust @ idle...?????
I had the car on, it was completely warmed up and i was sitting outside talking to my friend when he said, dude u have white smoke coming out of ur exhaust...i took a lap around the block, still there...what could it be?
Old Aug 5, 2001 | 12:52 AM
nEoMuGen's Avatar
Default Re: White smoke out of the exhaust @ idle...????? (NBP ITR 01-622)
What kind of gas you used?
Old Aug 5, 2001 | 04:02 AM
evil vapor's Avatar
Default Re: White smoke out of the exhaust @ idle...????? (nEoMuGen)
need more info on your set-up. First thing that comes to mind is a plugged up PCV valve. Scared me when I was running turbo, thought I blew the motor, changed out the valve and never had puffs of smoke come out of my car when I was waiting at a drive through. If it has a sweet smell, then it's coolant, if not, it's oil. Either way, you shouldn't be smoking. What is the miles on motor, ever rebuilt? Boost or NA, etc etc etc etc etc etc etc etc.
Old Aug 5, 2001 | 05:37 AM
len's Avatar
len
Default Re: White smoke out of the exhaust @ idle...????? (vaporsi)
White smoke equals burning oil.
Black smoke equals fuel burning.
Anything other than that sounds like coolant.
But check the PCV valve.
Old Aug 5, 2001 | 08:24 AM
Warren's Avatar
Wrong-Way Wang
Default Re: White smoke out of the exhaust @ idle...????? (ILOVERACING)
Actually white smoke is more likely coolant.
Whitish-blue is oil.
Black is gas.
Don't do the shake test on the PCV valve. It doesn't really rattle much. Take it out, clean it up, and blow on the bottom side to see if it lets air through, then blow from the other side to make sure it does not let air through. Incidently, Honda PCV valves are stupid expensive. It's 18 bucks for this PCV valve!
Warren
Old Aug 5, 2001 | 10:08 AM
Toda Party's Avatar
Default Re: White smoke out of the exhaust @ idle...????? (Warren)
my setup is stock except aem cai....
i did go check my oil level, it was a but low, i added some oil and it seems to be fine...i'm gonna go check the pcv valve right now
edit: oh yeah i used 92 octane
[Modified by NBP ITR 01-622, 7:08 PM 8/5/2001]
Old Aug 5, 2001 | 10:34 AM
EPGONZALEZ's Avatar
put your hand in the smoke and then smell your hand..you should know what it is when you smell it..
the smoke never goes away? you sure its not just the condensation in your pipes from parking over night?
Old Aug 5, 2001 | 10:38 AM
JDM R98's Avatar
Default Re: White smoke out of the exhaust @ idle...????? (EPGONZALEZ)
its probaly water in the exhaust piping , or its condense in there causing it to smoke
Old Aug 5, 2001 | 10:44 AM
evil vapor's Avatar
Default Re: White smoke out of the exhaust @ idle...????? (JDMR98)
ahh, you can get a PCV replacement either made by purolater or fram, they do the job without the price hike of Honda equipment. I was enlightened to read on the PCV box that it was recommeded to change it out every 15k. Now if you removed the breather for the valve cover, that valve must be clogged up.
Old Aug 5, 2001 | 02:07 PM
n1racer's Avatar
New User
its just water from condensation. it always happens to me in the morning. you know u gotta problem if it still happens when its like 90 degrees outside in the middle of the day.
bpfergu
Mar 5, 2012 05:27 PM
Mikeedubb
Oct 14, 2011 03:57 AM
dailyekhatch
Aug 15, 2011 06:45 AM
powwie
Apr 20, 2006 08:58 PM
HyperITR742
Aug 1, 2003 08:35 PM
