Can I run water lines like this?
Old Jul 25, 2003 | 01:05 PM
Poop111444's Avatar
Default Can I run water lines like this?
Ok, Im back on the road the now with my T3/T04e 50 trim turbo on my 99 Si with VAFC hack 450cc injectors. I just replaced a piston because i cracked a ringland.
Anyway, this new turbo i got is watercooled turbonetics. It has the 90 brass nipples, and they point down. I ran one with stainless line into right below the throttle body, and then other to coolant nipple right near the thermostat housing. I pretty much put it in a loop from the original configuration (regular hose from TB to nipple on head near thermostat)
Now the car idles high at 1500 RPM, has a CEL, and bucks around 1600-1700 RPM. But smooth up top.
Is that the cause or is it something else probably? I will check the CEL, and investigate it later, but im dead tired right now from working on the car all last nite and all this morning.
Thanks
done
Oct 14, 2005 12:24 PM
turboH22Aakkord
Jun 20, 2004 09:54 AM
Soccerking3000
Mar 1, 2004 08:28 AM
austrian type-R
Feb 16, 2002 05:19 PM
Ri5e
Dec 24, 2001 08:00 PM
