obd1 motor into obd2 civic
Old Jul 25, 2003 | 09:00 AM
Nextelbuddy's Avatar
Default obd1 motor into obd2 civic
im posibly getting a 97 civic coupe for reallly cheap like 1800 bux for the shell. i have a 95 gsr swap i want to put in it.other than the obd 2 ecu ill need, will it be possible to put the 95 gsr motor in the 97 civic as long as i use a obd 2 distributor and obd 2 injectors and a obd 2 altenator? or will that not work?
Old Jul 25, 2003 | 09:09 AM
aw1234dude's Avatar
Default Re: obd1 motor into obd2 civic (nextelbuddy)
I just did the same thing but with a b16 and if you do not want to go out and buy a new dizzy and alternator you can just rewire the plugs. It doesnt take too long. People say you just have to match the colors but my colors were all different so youll have to get a cheapy chiltons or get the pinouts on the internet. As for the injectors all b and d series injectors are the same, like 240cc. So you can just swap the stock d series injectors onto the gsr. Then you have to get a obd2 to bod1 conversion harness and connect up the obd1 ecu.
Old Jul 25, 2003 | 10:17 AM
iH8RICERZ's Avatar
Default Re: obd1 motor into obd2 civic (aw1234dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aw1234dude &raquo;</TD></TR><TR><TD CLASS="quote">I just did the same thing but with a b16 and if you do not want to go out and buy a new dizzy and alternator you can just rewire the plugs. It doesnt take too long. People say you just have to match the colors but my colors were all different so youll have to get a cheapy chiltons or get the pinouts on the internet. As for the injectors all b and d series injectors are the same, like 240cc. So you can just swap the stock d series injectors onto the gsr. Then you have to get a obd2 to bod1 conversion harness and connect up the obd1 ecu.</TD></TR></TABLE>
cant say it any better........ Also, in CA. its illegal to put an older motor in a newer car. I dont know how your emissions is over there, but you should check before actually doing it.
Hardrath_R
Aug 7, 2012 11:35 AM
hondaboy9506
Jan 19, 2011 10:08 AM
immikejones
Sep 3, 2005 07:15 PM
jaydm ferio
Nov 3, 2004 03:28 PM
aw1234dude
Jul 8, 2003 10:43 PM
