Quick Tranny fluid filling question
Old Jul 24, 2003 | 02:21 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Quick Tranny fluid filling question
My car is shifting like crap and goes into reverse with a big clunk. I know it's probably due to low fluid. I DO NOT need a flush. It's only been maybe 5-8K miles since the new block was installed.
Is there a way to fill the tranny with the car still on the ground? Or do I need 2 jackstands? 4 jackstands? I think there are two fill holes and 1 drain bolt. I do not need to access the drain bolt which I know is on the bottom of the tranny. Any pictures to help me add tranny fluid?
me when it comes to working on cars I don't want to drive the car again without taking care of this cause I'm afraid the tranny is going to lock up.
Old Jul 24, 2003 | 02:26 PM
.RJ's Avatar
.RJ
Default Re: Quick Tranny fluid filling question (RealTypeR)
You can fill by removing the VSS.... but without removing the fill hole on the side you wont know if its over-full or not, since you dont know how full/low the tranny is currently.
Old Jul 24, 2003 | 02:27 PM
AzG35's Avatar
You can take out the speed sensor and fill it up there. But it will be hard to tell how much you need without taking out the fill plug.
Default Re: Quick Tranny fluid filling question (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">You can fill by removing the VSS.... but without removing the fill hole on the side you wont know if its over-full or not, since you dont know how full/low the tranny is currently.</TD></TR></TABLE>
What's VSS? Is the side one accessible without jacking up the car?
.RJ's Avatar
.RJ
https://honda-tech.com/zerothread?id=382564
Old Jul 24, 2003 | 02:28 PM
Default Re: Quick Tranny fluid filling question (AzSi22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 &raquo;</TD></TR><TR><TD CLASS="quote">You can take out the speed sensor and fill it up there. But it will be hard to tell how much you need without taking out the fill plug.</TD></TR></TABLE>
I thought the speed sensor was just a plug?
Old Jul 24, 2003 | 02:29 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RealTypeR &raquo;</TD></TR><TR><TD CLASS="quote">
I thought the speed sensor was just a plug?</TD></TR></TABLE>
It is, but comes off completely by removing two 10mm bolts.
Old Jul 24, 2003 | 02:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=382564</TD></TR></TABLE>
a tutorial for a retard!!
Old Jul 24, 2003 | 08:30 PM
Art Vandeleigh's Avatar
Without knowing if you are low or not...I think the best bet would just be to flush the tranny. It is not difficult and will take you less then 20 minutes to do the whole job.
If you are in the bay area, you can bring the car to me and I can show you how to do it. Easy as pie
Old Jul 24, 2003 | 08:38 PM
Jack Black's Avatar
Default Re: Quick Tranny fluid filling question (Art Vandeleigh)
He is not in the bay area, he's over here.
Hey Marc, didn't you do your tranny fluid at Yack's on the way to Expo? Or was that Chris... Anyway, since you'll have to remove the fill plug no matter how you do it, you may as well just use the funnel with the long hose trick.
Old Jul 24, 2003 | 08:47 PM
Dave-ROR's Avatar
Realtor: Just. Call. D.
Old Jul 24, 2003 | 10:47 PM
IN VTEC's Avatar
It's just (1) 10mm bolt. It's the long one that sticks up. Remove it and wiggle the VSS out of mesh with the FD ring gear.
Use like 3 or 4 6" extensions if you don't wanna remove the intake.
17mm box wrench for the fill bolt to check your fluid level.
Maybe if you're real lazy, you can jack up the passenger-side, remove the 17mm fill bolt, slide a drain pan under the fill bolt (lowered??), put the car down, fill from the VSS until it starts to pour out from the fill hole, then jack the car up from the passenger-side again to hold the fluid in and replace the fill bolt.
Old Jul 25, 2003 | 03:50 AM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RealTypeR &raquo;</TD></TR><TR><TD CLASS="quote">I DO NOT need a flush. </TD></TR></TABLE>how do you know that?
I flush mine every ~5000-6,000 miles anyway.
j00 can do it!
Old Jul 25, 2003 | 05:18 AM
Default Re: Quick Tranny fluid filling question (dawhiteboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dawhiteboy &raquo;</TD></TR><TR><TD CLASS="quote">Realtor: Just. Call. D.</TD></TR></TABLE>
of course I called him and of course he saved my *** again.
faster Type R
Honda Civic (2006 - 2015)
Nov 11, 2009 04:12 AM
b20acura
Feb 2, 2007 12:15 PM
luderollin
Nov 19, 2006 07:30 AM
.one lane
May 2, 2006 05:38 AM
nfinitecc
Dec 3, 2004 03:47 PM
