where does the tranny fluid go?
were the hell do i pour in the tranny fluid on a d-serid tranny? i unbolt the side bolt and fill it till it starts coming out....correct? my chilton manual doesn't tell me ****. Thanks
Re: where does the tranny fluid go? (nfinitecc)
You're supposed to use a pump and fill it in from the side, but I just take the speed sensor off from the top-back of the tranny and fill it from there until it spill out from that hole. The speed sensor was held on by a 10mm bolt.
Look at this guide: https://honda-tech.com/zerothread?id=382564
Re: where does the tranny fluid go? (chowmien)
You jack up the car "level" open the drain bolt and add some into the VSS hole until you get some overflowing out.
If the car is'nt level it won't be the right amount.
team2n1hatch
06-30-2003 04:00 PM
