NEEED HELP RIGHT AWAY... JRSC and HONDATA
Old Jul 24, 2003 | 08:48 AM
ATgrills.com's Avatar
Default NEEED HELP RIGHT AWAY... JRSC and HONDATA
My local hondata installer just told me i need map sensor relocater in order to install the hondata on my JRSC type R???
is this true? what exactly do I need to run hondata on my car??
Ia matt talking about the missing link???
Thanks
Tyler
Modified by ATgrills.com at 10:03 AM 7/24/2003
Old Jul 24, 2003 | 09:18 AM
Spunkster's Avatar
Default Re: NEEED HELP RIGHT AWAY... JRSC and HONDATA (ATgrills.com)
No, you do not need the missing link. If you call Jackson Racing, tell them you need the map relocator for a Type R. They will know exactly what you need.
Old Jul 24, 2003 | 09:46 AM
falcongsr's Avatar
What is this crap?
Default Re: NEEED HELP RIGHT AWAY... JRSC and HONDATA (Spunkster)
or you can do what i did - go score extra map sensor (used, cheap etc), and plug a vacuum line into it (securely) from the intake manifold (after the SC) and just leave the stock map sensor in place to plug the hole.
Old Jul 24, 2003 | 09:50 AM
Spunkster's Avatar
Default Re: NEEED HELP RIGHT AWAY... JRSC and HONDATA (NOT EVIL falconGSR)
That will also work, but the install will not be as clean
Old Jul 24, 2003 | 11:47 AM
Rory Breaker's Avatar
Thats what I did as well. They also make blockoff plates you can get. STR makes a cheap one if I remember right, and Inline Pro makes a more expensive one.
I still need to get Sakai his map sensor back
Old Jul 24, 2003 | 03:32 PM
falcongsr's Avatar
What is this crap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spunkster &raquo;</TD></TR><TR><TD CLASS="quote">That will also work, but the install will not be as clean</TD></TR></TABLE>
clean? yeah right! my car is so fast it has to have TWO map sensors!
seriosuly, its not hard to make a decent plate to block it off if you can seal it well. (o-ring) but it was easier at the time to score an extra map sensor.
import-tooner
Jan 18, 2011 07:43 PM
integra123
Dec 7, 2005 03:29 PM
01JrscGSR
Apr 7, 2005 12:34 PM
morepoop4u
Nov 16, 2002 05:23 PM
