Undercarriage vibration
Old Jul 24, 2003 | 06:47 AM
CapnChunk's Avatar
Default Undercarriage vibration
I searched through the archives and found a few things about the undercarriage vibration that some people have had. The one thing that they said was the cat heat shield rattled at 2400 rpm, but when I look at my automagic tach (in a stylish 94 EX) it says roughly 2000. Is the automagic tach that far off or is my problem not the same as other peoples? I just had the wheels rebalanced and that didn't solve the problem, so now I'm willing to try anything. I can't drive at 45 mph without that vibration making my drive to work a real pain.
Old Jul 24, 2003 | 07:25 AM
JimBlake's Avatar
Default Re: Undercarriage vibration (CapnChunk)
I'd describe a loose heatshield as more of a tinny rattling sound. Not a vibration that you feel. And depending on how it's loose or bent, it can happen at other rpms.
Did you check your wheels & tires for out-of-round? If you had 'em balanced, the tech might not have looked for that if you didn't ask.
Old Jul 24, 2003 | 09:44 AM
NathanMorris's Avatar
Default Re: Undercarriage vibration (JimBlake)
get tires balanced, check lug nuts.
Old Jul 25, 2003 | 06:57 AM
CapnChunk's Avatar
Default Re: Undercarriage vibration (92Lx)
Got my wheels balanced again - and the lugs are on ok because they used a torque wrench and all that. Maybe it's just me but I think it's the worst just as it's changing from drive to overdrive. Like if you're floating around 2k and cruising and it wants to shift. So I'm thinking that maybe a mount of somekind or maybe my trans. A guy was telling me that I need my alignment done again.
Old Jul 25, 2003 | 07:21 AM
YeuEmMaiMai's Avatar
how many miles on the car?
transmissions do age and shift quality will degrade at some point in time... try changing the atf
Old Jul 25, 2003 | 08:32 AM
CapnChunk's Avatar
Default Re: (YeuEmMaiMai)
It's got 135,000 on it - and compared to a few other 5th gens I've seen, my car is far from dead. I'll give a trans flush a shot.
Old Jul 25, 2003 | 01:20 PM
DrunkNRacer's Avatar
Default Re: (CapnChunk)
I would definetly flush the tranny anyway.. u should do that since your car has so many miles on it. Your problem could very well be the synchros in your transmission.. and god lets hope not.
Old Jul 25, 2003 | 01:45 PM
p0pe's Avatar
Default Re: (G-villeRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G-villeRacer &raquo;</TD></TR><TR><TD CLASS="quote">I would definetly flush the tranny anyway.. u should do that since your car has so many miles on it. Your problem could very well be the synchros in your transmission.. and god lets hope not. </TD></TR></TABLE>
I get a vibration w/ noise around 2000-2500 rpms, usually at very low speeds shifting from 1st to 2nd. It seems like it only happens when I shift slow and the RPMs fall too much. It sounds more like the heat-shield though, like something resonating with the vibration caused by the shift.
My car has 78k miles on it, so I doubt it would be the synchros going... but I do need a new clutch so maybe thats causing the vibration at low rpms..
Old Jul 25, 2003 | 02:12 PM
CD8's Avatar
CD8
is the vibration only under acceleration? if so it maybe your CV joints (axles).
Old Jul 26, 2003 | 04:05 PM
CapnChunk's Avatar
Default Re: Undercarriage vibration (CD8)
the wierd thing about the vibration is that it doesn't really happen under acceleration. Usually just happens while I'm just cruising along. But today I noticed that while in neutral and park, if I rev the engine - at 2200 I get the same wierd vibration. doesn't happen below 2200 and doesn't happen over 2650. It's simply the wierdest thing.
Old Jul 26, 2003 | 06:19 PM
karpieldisco's Avatar
I have had the same proble. The TSB on the rattle is that it is 1800-2200 . I had the same proble, 2.00 fix. Pipe clamps around the shield or just cut it off.. Hope this helps
Old Jul 26, 2003 | 08:13 PM
Default Re: Undercarriage vibration (karpieldisco)
cut the shield off.
Old Jul 27, 2003 | 08:25 AM
CapnChunk's Avatar
Hate to sound so lame - but what exactly is the TSB and where do I find it to cut off the shield around it?
Old Jul 28, 2003 | 05:03 PM
CapnChunk's Avatar
Again - anyone and the TSB?
Old Jul 28, 2003 | 06:04 PM
CD8's Avatar
CD8
i have no idea what the TSB is, but have someone rev your car to 2200 rpm while your on the outside/under and see where exactly the rattle is coming from. you may not even need to cut it off, possibly just some loose bolts.
Old Jul 28, 2003 | 06:40 PM
CapnChunk's Avatar
Hopefully it's a loose bolt or two - I hate the idea of doing weight reduction one heat shield at a time
Old Jul 28, 2003 | 11:28 PM
CD8's Avatar
CD8
hehe gotta start somewhere!
westsnip
Sep 5, 2008 01:13 PM
ek9child
Apr 2, 2008 01:04 PM
teg969
Apr 25, 2007 03:41 PM
changolokko
Sep 24, 2002 06:24 PM
