Boost Lvls on Stock Ls motor?
Old Jul 24, 2003 | 02:11 AM
Slo_Akord's Avatar
Default Boost Lvls on Stock Ls motor?
I'm NoOB turboing Hondas -ex DSM owner. What are safe boost lvls to run on a stock ls motor? Also afc hack or FMU? Thanks
Old Jul 24, 2003 | 04:04 AM
st00pid's Avatar
Default Re: Boost Lvls on Stock Ls motor? (Slo_Akord)
well here goes... again.
20 psi on Hondata. stock LS short block with Block guard. 93 octane
Old Jul 24, 2003 | 04:14 AM
DaveF's Avatar
Default Re: Boost Lvls on Stock Ls motor? (st00pid)
id say 10 psi on 93 octane with good tunning.
Old Jul 24, 2003 | 07:59 AM
99lspwr's Avatar
Default Re: Boost Lvls on Stock Ls motor? (2.2Lcivic)
10-11 psi untuned with 3 deg ret. timing or btm.... 14 psi tuned....I am using a 150k mi. + motor (bone stock and orig) pushing 10 psi w/ no problems...
Old Jul 24, 2003 | 08:16 AM
mskibbz-T's Avatar
Default Re: Boost Lvls on Stock Ls motor? (99lspwr)
It all depends on how much CFM your turbo is pushing... Boost levels are irrelevant without knowing what turbo you will run.
Old Jul 24, 2003 | 04:10 PM
modvp's Avatar
Default Re: Boost Lvls on Stock Ls motor? (mskibbz-T)
I had my drag III at 10-12 psi, with 12 degrees of timing with at 50 trim compressor/.63 ar turbine T04/t3 turbo, 310 cc injectors, and a 8:1 vortech FMU. car ran fine. no problems. i ran 93 octane all the time.
89-civic
Jan 13, 2006 01:03 PM
hatchyboy89
Dec 16, 2004 06:22 PM
_SHEP_
Sep 27, 2004 08:17 PM
phear
May 7, 2002 03:41 PM
H22CIVIC
Oct 14, 2001 10:57 AM
