How much boost can my bottom end internals take
Re: How much boost can my bottom end internals take (H22CIVIC)
deppends on what you have. . . .fuel set-up. . . . piggyback. . . . . .stand alone. . .?
New User
Re: How much boost can my bottom end internals take (On Point)
Because I have a H22 Lude motor in my EG right now, but I am throwing in a LS turbo setup! As for now, I am just learning about forced induction. I want to run 12-13lbs boost on this LS motor, what do I need to do!
New User
i heard you cant boost more then 10 lbs with stock internals,im currently boosting
7 lbs on a stock ls turbo
well h22 you know how hard my car pulls I have heard and read over the years 10 psi safely on stock bottom end! if you plan on getting a drag III kit get them to change the plate in the vortech FMU to a 8:1 and getting some injectors! don't get the delta waste gate upgrade to the tial much better! the stock block will handle 10 psi as I have run it a few times and everything feels fine! I have boosted to 12psi once by accident ( when I blew my cat off my car and I was running just the down pipe! man it was fast..) personnaly I would just run 10 psi for now. as you will be incredibly fast! but what ever you decide I will help u install it!
H22*CiViC
05-23-2011 04:01 PM
Chip398193
11-19-2001 10:55 AM
