Coolant bypass utterly confused HELP (56k warning)
Old Jul 23, 2003 | 06:02 PM
Dan GSR's Avatar
Default Coolant bypass utterly confused HELP (56k warning)
I tried searching, but lead me to broken links and I'm still confused
I have three pictures with 9 different spigots that I don't know what to do with them.
Can somone tell me what number to connect to what number?
I want to bypass the throttle body of any coolant, and I want to bypass the intake manifold of any coolant ( I'm using the hondata IM gasket)
Old Jul 23, 2003 | 06:27 PM
Dan GSR's Avatar
I did more searching
I think I got it
1 goes to 4 to bypass the t-body
2 get T'd with 9
5,6,7,8 isn't used
will my cold idle or fast idle be weird? Do I have to remove anything else?
And I don't have to drill the thermostat?
Modified by Dan GSR at 10:42 PM 7/23/2003
Modified by Dan GSR at 10:47 PM 7/23/2003
Old Jul 23, 2003 | 07:18 PM
mmuller's Avatar
Mad Scientist
Default Re: (Dan GSR)
Ok, i dont think you would wanna bypass the iacv, the car would idle like **** or not idle at all, you can bypass the fast thermo valve thingy, but dont think you have one so:
#6 to #1
#7 to #4
#3,5 not used
if you dont want the heater then #9 and #2 go together
# 8 not used
Old Jul 23, 2003 | 07:19 PM
tinkerbell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">I did more searching
I think I got it
5,6,7,8 isn't used
search again, this is wrong.
they all are used for your thermostat bypass and heater core...
tinkerbell's Avatar
Default Re: (tinkerbell)
except 8 which is from tb...
Old Jul 23, 2003 | 07:23 PM
tinkerbell's Avatar
oh, you are bypassing heater core???
have you cut the hole out of the gasket where 5 is? if no, good
yes, you need to remove or drill a big hole in your thermostat...
you can bypass teh IACV - it is only given coolant to prevent freezing...
t..
Old Jul 23, 2003 | 10:42 PM
sgT's Avatar
sgT
Default Re: Coolant bypass utterly confused HELP (Dan GSR)
Plug the following: 1 and 4
Leave open the following: 5,6,7 and 8
Route the following:
2 to heater core outlet
9 to heater core inlet
3 to heater line for #9
Old Jul 24, 2003 | 07:09 AM
Xsi's Avatar
Xsi
This might help: http://www.lyonel.orcon.net.nz/tb_bypass.htm
Old Jul 24, 2003 | 08:49 AM
owen_the_soyboy's Avatar
Default Re: Coolant bypass utterly confused HELP (sgT)
he can only leave #5 open if th ehondat intake gasket has a blockoff plate for thathole, some do not as far as I know....
Old Jul 24, 2003 | 08:51 AM
Suprdave's Avatar
Default Re: Coolant bypass utterly confused HELP (owen_the_soyboy)
nm
zemerin
Apr 4, 2014 04:56 PM
phrenzykEG6
16
Jun 17, 2010 08:42 PM
hughesl
Apr 30, 2005 01:51 PM
Sinner
May 29, 2003 10:41 AM
Doctor CorteZ
Feb 13, 2002 01:53 AM
