another skunk2 camber kit story
Old Jul 23, 2003 | 05:24 PM
ATS*Mark's Avatar
OG triple OG
Default another skunk2 camber kit story
ok , ive been noticing a bad poping noise in my left front suspension , i thought it was my drivers side axle , but it wasnt i guess..... it got wors and finally i went to check it out . i had reciently put poly front control arm bushings on so i thought that i might have also left somthing loose or what not. well i notice my skunk2 ball joint boots are blown to **** . apon closer inspection of the right front in comparrason to the left , the left ball joint was sticking up much much higher than the right. well if you dont know about skunk2 balljoints . there held onto the plate by a snap ring , well that snap ring came loose so the ball joint was just moving up and down probably 3 to 4 inches , i was ******* pissed!!!!!!!!!! so i put poly boots on there from my hyperflex kit and retightened everything down , and next paycheck i guess ill have to buy the replacement balljoints . **** skunk2 balljoints!
thanks for letting me vent , has anybody else had this problem and how did u fix it , did skunk2 do anything about it?
Old Jul 23, 2003 | 05:29 PM
slowEJ6's Avatar
Default Re: another skunk2 camber kit story (TURSpoonEK)
damn man that sucks........but ive heard from a few people pretty much the same story with the skunk2 camber kit.....
sorry to hear
Old Jul 23, 2003 | 05:39 PM
eg crunkmonster's Avatar
i hope skunk2 knows this problem and fixes it.....i would call/write skunk and explain the problem. they might replace it. they replaced my friends valve springs that broke.
Old Jul 23, 2003 | 06:02 PM
ATS*Mark's Avatar
OG triple OG
Default Re: another skunk2 camber kit story (eg cookiemonster)
ya im pretty sure they know because they sell replacement ones , i emailed them we shal see what that does , maybe theyll hook me up
Old Jul 23, 2003 | 06:13 PM
Mashimaro's Avatar
i'm kinda annoyed about my skunk2 kit as well now...i just found out what the creaking noise was caused by. the material on the ends of the kit extend longer than the OEM ones by almost 1cm. it was rubbing bad enough in my wheel well and camberkit that metal is showing on both. i took them off, cut off 1/2 a cm and ground it smooth then used touch-up paint on them. noise is gone now and my sanity has somewhat come back. i'm just pissed that this happened considering it was made for EG/DC cars.....
keep us posted on what happens with your ball joints..i'll keep an eye on mine. thanks.
Old Jul 23, 2003 | 06:40 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (Mashimaro)
ya mine are almost hitting , they miss my fenderwell by about an 1/8 in or so
Old Jul 23, 2003 | 07:45 PM
FF-sean's Avatar
Default Re: (TURSpoonEK)
skunk camber kit....is not really recommended specially if your car is lower than 2' just a waist of money IMO i would rather get some ingalls....
Old Jul 23, 2003 | 07:48 PM
Trbospnkr's Avatar
haven't you herd of Skunk Junk. Skunk sucks *****.
Old Jul 27, 2003 | 07:21 PM
ATS*Mark's Avatar
OG triple OG
Default Re: another skunk2 camber kit story (Trbospnkr)
well there customer service sucks too , they never got back to me after a week
Old Jul 27, 2003 | 08:07 PM
euclid's Avatar
same ish happened to me, same popping sound as well. i called skunk about it and told them that ive heard alot of people having this problem, they said that my car must be lowered too much b/c they have not been having a problem. i must be stunna slammed to the ground fo sure y0
anyway i had to pay 60$ for a new pair of plates/balljoints... if these break im tossing the kit. but i dont have any rubbing problems as of yet(knock on wood)
Old Jul 27, 2003 | 08:09 PM
FF-sean's Avatar
Default Re: another skunk2 camber kit story (euclid)
SKUNK2 SUCKX
Old Jul 27, 2003 | 08:14 PM
euclid's Avatar
Default Re: another skunk2 camber kit story (ReaL JDM Eg6)
nice short shifters
Old Jul 28, 2003 | 05:26 PM
ATS*Mark's Avatar
OG triple OG
i guess ill order mine this weekend
Old Jul 28, 2003 | 05:53 PM
M-EJ1's Avatar
Same exact problem here... the ball joints themselves aren't the culprit I don't think, it's the fact that they use shitty-*** boots that crack/tear after only a few hundred miles. After that the ball joint is left exposed and it all goes downhill from there.
My second replacement set is on order, at 68 bucks for both sides with shipping. Skunk2 will not replace them because they claim that it's because my car is too low. I call bullshit, but they won't give in and send me a free set. This time however, I'm going to be using poly ball joint boots from my ES hyperflex kit, so hopefully this set will last longer than the last two. It's getting goddamn expensive, but I don't have the stock control arms and no one else makes a kit like skunk2's (replacement A-arm) for 5th gens, as far as I can tell.
Old Jul 28, 2003 | 06:05 PM
Fuster_Cluck's Avatar
Are these the parts you guys are talking about?
That is 6 months on my 98 Civic last year
The thread can be read here: https://honda-tech.com/zerothread?id=346142
....and I have a skunk2 kit in my room waiting to go on my Eg (brand new).
Debating if I should sell it or what
Old Jul 28, 2003 | 06:41 PM
Racerage1's Avatar
i was gonna go with skunk2's for my car but heard so many bad things about them. i ended up getting spc for the fronts and my car is dropped a lil more than 2 inches. no rubbing and no problems. and u can adjust caster as well. plus it looks and feels like a quality piece... for SPC
Old Jul 28, 2003 | 06:50 PM
SpooN Man's Avatar
Default Re: another skunk2 camber kit story (Racerage1)
I wish Srr made a front kit. I know that we could sell it for alot cheaper !
How is the SRR Lca's holding up
Old Jul 28, 2003 | 06:58 PM
M-EJ1's Avatar
Default Re: another skunk2 camber kit story (Hybrid93Hatch)
Hybrid: yep that's the boot that splits. As soon as that happens all the grease comes out of the ball joint and it eats itself. Hopefully you caught yours in time to just replace the boots and repack the ball joints, but mine were completely shot.
Old Jul 28, 2003 | 07:18 PM
Default Re: another skunk2 camber kit story (M-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">Hybrid: yep that's the boot that splits. As soon as that happens all the grease comes out of the ball joint and it eats itself. Hopefully you caught yours in time to just replace the boots and repack the ball joints, but mine were completely shot. </TD></TR></TABLE>
Damn! My Eg skunk2 kit is the same as the one in the pic (Ek)
Anyone have pics to post of the SPC front camber kit? I would like to see how they look in comparison to the skunk2. I think I'm going to sell the skunk2 and go with another kit.
jdmhondaparts.com is where I bought the kit. Not helpful at all from the time I bought the kit and asked a couple Q's to the time I told them about the problem.
euclid's Avatar
it is probibly important to know that the new balljoints they sent are not the same design as the old ones that ripped, i dont know if it will make a difference though.
Old Jul 28, 2003 | 07:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euclid &raquo;</TD></TR><TR><TD CLASS="quote">it is probibly important to know that the new balljoints they sent are not the same design as the old ones that ripped, i dont know if it will make a difference though. </TD></TR></TABLE>
Now that you mention that I remember a thread about skunk making new covers that would not rip as easy.......
https://honda-tech.com/zerothread?id=281597
Most of the pics aren't working in the thread above now. Does anyone know how to identify the old ball joint covers from the new ones?
Old Jul 28, 2003 | 08:46 PM
ATS*Mark's Avatar
OG triple OG
my ball joints were completly seperated from the mounting plates with alot of play in the drivers side , **** thos ball joints i hope the new ones are better...
and spoon man im lovin my srr lcas thanks for the good pricing!
Old Jul 28, 2003 | 09:13 PM
Racerage1's Avatar
i dont have a pic of mine cuz i dont have a digi cam yet...but i found a post of a guy here who actually e-mailed the company regarding ball joints failing on other camber kits here's what he said:
Quote:
i just got one for my 2000 ex from http://www.groupbuycenter.com
I am very impressed with the quality of the camber kit. i ordered the one that replaces the front control arm and has a ball joint pressed in to it already. i asked SPC about the quality of the ball joint and they said:
"You shouldn’t have a problem with these arms. We have been selling them for about 4 years and I haven’t seen a ball joint failure come back. The people that make this arm to our specs manufacture OEM ball joints & bushings. If at some point you do wear out the ball joint they are part of our line of replacement parts. I don’t know of any ball joints that were sold as replacements for the 62010 arms. As part of our ISO-9001 program we continuously test new products, inspect & test new incoming parts and monitor product returns for problems. That is just one reason that we stand behind our products and have been so successful in the sport compact car market.
Good luck with your car!
Joe L. Baker, VP Engr/QA"
Old Jul 28, 2003 | 09:47 PM
EKweezy's Avatar
my lasted 4 months, both dead, so is it that, that makes the poping sound, i didn't think it is that because my axles move in and out
civichb98
Suspension & Brakes
20
Aug 29, 2010 10:25 AM
vanny_david
Suspension & Brakes
10
Nov 20, 2009 09:39 AM
hyrev20
Apr 7, 2009 04:47 PM
Dartanian
Suspension & Brakes
Jul 28, 2007 12:52 PM
4drRacer
Oct 12, 2003 09:55 PM
