flushing radiator?
Old Jul 23, 2003 | 12:36 PM
SIMATIC's Avatar
Default flushing radiator?
im gona flush my coolant soon on my 98 accord ex. im gona buy honda coolant at the dealer but i need to be sure how to flush it.
i think its drain radiator and fill with water. then run engine to let circulate aND drain radiator. then fill the radiator again with the engine "on" with 50/50 mixture until full and fill resivoir tank. sound right?? thanks.
Old Jul 23, 2003 | 12:51 PM
JimBlake's Avatar
Default Re: flushing radiator? (SIMATIC)
Turn the heater **** all the way to hot & open the drain plug in the back of the engine block, too. Otherwise there's a lot of coolant that doesn't drain.
I like to use distilled water.
Old Jul 23, 2003 | 01:04 PM
YeuEmMaiMai's Avatar
I usually drain fill with wather run car 3 mins empty fill with flush and distilled water run for time indicated, flush with distilled water, fill with distilled water and proper amt of anti freeze
Old Jul 23, 2003 | 08:36 PM
SIMATIC's Avatar
Default Re: flushing radiator? (YeuEmMaiMai)
o0 wheres the plug located on the engine block? which side, can i reach it from the top.? thanks
Old Jul 23, 2003 | 11:01 PM
david90's Avatar
I think it is underneath ur car near the middle front.
Old Jul 24, 2003 | 03:36 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIMATIC &raquo;</TD></TR><TR><TD CLASS="quote">o0 wheres the plug located on the engine block? which side, can i reach it from the top.? thanks</TD></TR></TABLE>
You say '98 Accord, but you don't say 4 or 6 cyl... I don't know where the drain is on a V6; if it even has one.
Mine's a 4-cyl, and the plug is on the back of the block, to the left of the oil filter. It's way easier to reach from underneath. With the car up on ramps that makes it drain easier anyway.
Old Jul 24, 2003 | 07:40 AM
GimpyAccord's Avatar
Default Re: flushing radiator? (JimBlake)
There is a radiator drain on the front middle of the radiator as the earlier posted said... facing the rear of the car. The bolt on the block you're reffering to is the block cooling passage drain and its also a good idea to push out via that too as sediments etc tend to collect inside the block.
Honda coolant? I use whatevers on sale bud... so unless its cheap don't bother IMO. After a few hundred thousand miles on my car I don't think its hurt it
Old Jul 24, 2003 | 08:48 PM
SIMATIC's Avatar
Default Re: flushing radiator? (GimpyAccord)
yea its a 4cyl -5 spd. with 127k. jst got it. thanks for the help. ill clean the dust off those ramps and put them to use
whiteGSR
Jul 26, 2022 03:06 PM
justinwebb
23
May 6, 2009 08:24 PM
batac_boy
Honda Civic (2001 - 2005)
Mar 23, 2008 05:59 AM
DIRTYsouthBB6
Jul 13, 2006 09:51 AM
return_2020
14
Oct 19, 2005 09:23 PM
