idle problem...
Old Jul 23, 2003 | 11:48 AM
nY's FiNeSt's Avatar
Default idle problem...
Alright, usually when i start my car it sits at 2500 until it warms up, then drops down to about 600 - 700. Today i'm driving around and i was sitting at a light and it wouldn't drop below 1400 -1500 rpm. I checked my throttle cable to see if it was loose, but it wasn't. I really don't know what it could be. Maybe throttle position sensor? Can you guys please help me out!
John
Old Jul 23, 2003 | 01:15 PM
Default Re: idle problem... (nY's FiNeSt)
anyone, i need help
Old Jul 23, 2003 | 02:00 PM
fred92htch's Avatar
I just went through this...
https://honda-tech.com/zerothread?id=558236
Old Jul 23, 2003 | 02:39 PM
blackhatchy's Avatar
Default Re: idle problem... (fred97gle)
yeah theres a billion people with idle problems, me included. just search and you can find out whats wrong instead of waiting for a response
Old Jul 23, 2003 | 02:41 PM
Default Re: idle problem... (blackhatchy)
thanks
Old Jul 23, 2003 | 03:51 PM
slvrcivic97's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackhatchy &raquo;</TD></TR><TR><TD CLASS="quote">yeah theres a billion people with idle problems, me included. just search and you can find out whats wrong instead of waiting for a response </TD></TR></TABLE>
So true. I have a big idle problem too that I dont think will ever get fixed.
Old Jul 23, 2003 | 03:52 PM
Default Re: idle problem... (slvrcivic97)
i just checked my coolant level, and i was a tiny bit low, so i added some. Made no difference.
then i adjusted the flat head screw on the TB to adjust the idle, lowered the idle to 1000 - 1100 but it still fluctuates.
Old Jul 23, 2003 | 05:07 PM
bump
Old Jul 23, 2003 | 09:33 PM
ttt
Old Jul 23, 2003 | 10:34 PM
hondasleeper's Avatar
Check your Idle Air Control Valve(IACV), that might have gone bad. It happened to me a couple of weeks ago. Do the diagnostics from the Honda Manual, just to make sure it is the IACV that has gone bad cos those things are not cheap approx $120 from Honda.
Old Jul 24, 2003 | 12:05 AM
Default Re: idle problem... (hondasleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondasleeper &raquo;</TD></TR><TR><TD CLASS="quote">Check your Idle Air Control Valve(IACV), that might have gone bad. It happened to me a couple of weeks ago. Do the diagnostics from the Honda Manual, just to make sure it is the IACV that has gone bad cos those things are not cheap approx $120 from Honda.</TD></TR></TABLE>
if it was my IACV, wouldn't my engine check light come on? Mine hasen't
Old Jul 24, 2003 | 01:59 AM
Miles85916's Avatar
check the disturbor, ecu, if u have a vafc check all that, swap ecu if u have to and see if its doing anything different, i am not a vafc certified but i have a friend that is and i watch him do those stuff, idle problems are a bitch to fix
Old Jul 24, 2003 | 07:40 AM
Default Re: idle problem... (Miles85916)
bump
Old Aug 8, 2003 | 09:59 PM
UP, still haven't figured it out
Old Aug 8, 2003 | 10:16 PM
gezer's Avatar
maybe a vac leak?
Old Aug 8, 2003 | 10:35 PM
Default Re: idle problem... (gezer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezer &raquo;</TD></TR><TR><TD CLASS="quote">maybe a vac leak?</TD></TR></TABLE>
checked all tubes for leaks
Old Aug 9, 2003 | 09:57 PM
Old Aug 20, 2003 | 09:17 AM
FIXED!!!
Old Aug 20, 2003 | 09:20 AM
fred92htch's Avatar
What did you do?
Old Aug 20, 2003 | 09:23 AM
it was the sensor behind the IM, i think the iacv? i'm not too sure, me and my buddy were fixin it at like 12 last night
jdm4drSi
Apr 6, 2007 08:19 AM
94Integra_Ls
Feb 14, 2007 10:01 PM
shinobijesus
Mar 13, 2005 04:54 PM
..::91TEG-G2::..
Jan 26, 2005 10:01 AM
kb158
18
Jul 30, 2004 02:43 PM
