H22A in 99 Integra Help!
I was wondering what i need to do to swap a h22a into a 99 Gs-R ObdII do i just need a H22a vtec with obd2 and it just bolts in with new mounts?
-joe
-joe
There may be some wiring involved. Use a good urethane mount kit, and buy an H22 that is 0bd2...this will make the swap alot easier!
Easiest way for that swap would be to use your GSR harness on the H22. And use your GSR computer. The GSR computers run the H22's great!!!! The only that will be left out with the GSR computer is the EGR system on the H22. No big deal!!
Use the Hasport Civic H22 kit 92-95 Civic and it will also fit the 94-00 Integra as well.
My best recommendation is to retain your stock wiring harness and just lengthen the alternator wiring.
ace1875
Dec 15, 2002 08:30 AM
