LS/vtec question
i am just doing some research on setting up an ls vtec ... im going with pr3 pistons on the ls rods with a b16 head/ctr cams .. my question is i read everywhere to upgrade the ls rodbolts if i want to run to 7900,8000rpms.. can i use b16 rod bolts on the ls rods...i dont want to go pass the b16 redline so someone help me out.
thanks in advance
thanks in advance
so this wont work ?? what do you mean by bottleneck? since im not out at the track all time i figured i could stick with oem parts.
I have heard a couple people say they used the b16 bolts and they worked well up to stock redline... plz correct me if im wrong its just i have a new set of 16a rod bolts sitting here and would rather use them if i could.
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinegsr »</TD></TR><TR><TD CLASS="quote">ARP bolts...they are like $100-125</TD></TR></TABLE>
whoaaaaaaaaaaah........i got mine for 36...
stock rods are fine for all motor applications..arp rod bolts and acl or gsr bearings are recomended
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Try2Live4God »</TD></TR><TR><TD CLASS="quote">Why would you wanna go with an LS/VTEC setup? I hear that setup is not that great....</TD></TR></TABLE>
you shut up.
you shut up.
since you heard is not that great maybe cause they did it the gettho way
or got it done at "full throttle" LOL
but get done right wich takes a lot of $$$
and you will be satisfied with it
All of you guyz iz probably right...but it all boils down to reliability. Honda would've done it to begin with if it was all that great. But, everyone is entitle to they opinion, and my personal take on it is a waste, juss buy a B18C1 if you gonna drop all the greenbacks to get an LS/VTEC!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Try2Live4God »</TD></TR><TR><TD CLASS="quote">All of you guyz iz probably right...but it all boils down to reliability. Honda would've done it to begin with if it was all that great. But, everyone is entitle to they opinion, and my personal take on it is a waste, juss buy a B18C1 if you gonna drop all the greenbacks to get an LS/VTEC! </TD></TR></TABLE>
you shut up.
you shut up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIntegra99 »</TD></TR><TR><TD CLASS="quote">How much does the full LS\Vtec swap cost the right way. I was guessing around 4k</TD></TR></TABLE>
including itr tranny & lsd..more like 6K+. btw, theres no need for eagle rods for your setup, its overkill.
why spend 6 grand on ls vtec when you can get a type r full swap for like 4500? plus have the reliability of a stock honda motor.?????? i'm sorry but 6 grand is a waste... just to have something that a semi built gsr will smoke.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohc-nyne »</TD></TR><TR><TD CLASS="quote">
I meant the set..rod and head bolts. Smart investment to go ahead and upgrade the head bolts also so you have no fears of it lifting at high rpms.
</TD></TR></TABLE>I meant the set..rod and head bolts. Smart investment to go ahead and upgrade the head bolts also so you have no fears of it lifting at high rpms.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eclipse spanker »</TD></TR><TR><TD CLASS="quote">Ls/vtec
There are better, more reliable ways to go faster for that amount of money. </TD></TR></TABLE>
listen you ********, stop dissin the ls/vtec b/c you dont know **** about it!
There are better, more reliable ways to go faster for that amount of money. </TD></TR></TABLE>listen you ********, stop dissin the ls/vtec b/c you dont know **** about it!
Trust me...my father works for Acura. As I said, it's a waste of money...and Honda would've thought of that great idea in the first place.....just invest in a B18C5 and get the JDM conversion as everyone else was saying....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Try2Live4God »</TD></TR><TR><TD CLASS="quote">Trust me...my father works for Acura. As I said, it's a waste of money...and Honda would've thought of that great idea in the first place.....just invest in a B18C5 and get the JDM conversion as everyone else was saying.... </TD></TR></TABLE>
If Honda had thought that RWD was a great idea, all Hondas would have it. If Honda thought that Turbo was a great idea then they would have done that too. If your dad thought that using a condom was a good idea...
No, Trust me, you need to beat the $hit out of your English teacher!!! Also, who cares if your Dad works at Acura? For all we know he's a damn janitor there!
