Would this cause ECU damage?
Old Jul 22, 2003 | 07:42 PM
turbotime's Avatar
Default Would this cause ECU damage?
I had a fire in my engine bay, it didnt damage any internals but it did melt a few wires/plugs in the engine bay. Could this cause a "short" in my ecu? My car still runs but it runs poorly and then throws a CEL randomly and goes to ****, ive tried every other possible cause so what do you all think?
Old Jul 22, 2003 | 07:43 PM
Daniel's Avatar
Default Re: Would this cause ECU damage? (turbotime)
What code is the ECU throwing?
Old Jul 22, 2003 | 07:46 PM
turbotime's Avatar
code 1: o2 content
thing is its got a brand new o2 sensor and no exhuast leaks.
Old Jul 22, 2003 | 07:48 PM
b16ahybrid's Avatar
Default Re: (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">code 1: o2 content
thing is its got a brand new o2 sensor and no exhuast leaks.</TD></TR></TABLE>
Is it a honda 02 or cheap auto parts store o2 sensor?
how is the wiring from the o2 to the ecu? maybe there is a bad connection. Was that one of the wires effected by the fire?
Old Jul 22, 2003 | 08:03 PM
turbotime's Avatar
its a universal o2, but i had an oem one and it did the exact same thing. Wiring is good and i even moved the o2 to the second bung so it wouldnt get so hot. No difference.
Old Jul 22, 2003 | 08:40 PM
salbaje's Avatar
when the wires melted it might have shorted something on the ecu. open the case up and see if any burn marks. Try another ecu from a friend
Old Jul 22, 2003 | 09:06 PM
turbotime's Avatar
I opened the case and they're arent any obvious burn marks. I live in bumfuck, md so i dont have anyone i can swap ecu's with. My only option is to buy a new one and hope thats it, so before i do so i want to make sure it COULD BE fried.
Old Jul 22, 2003 | 09:18 PM
b16ahybrid's Avatar
I would double check the o2 make sure the is voltage leaving the o2 sensor and make sure there is voltage at the ecu, if there is voltage at at the ecu then it may be the ecu...
A poor connection (must be soldered no wire taps) will cause a o2 code, although it may work in most cases it won't
Old Jul 22, 2003 | 09:21 PM
HATCHMO92's Avatar
this is kinda dumb , but why not replace the whloe harness ? it might not fix the o2 proplem but with a melted harness who know's what could come up next.
Old Jul 22, 2003 | 09:26 PM
FULLTHROTTLE's Avatar
Default Re: (HATCHMO92)
The 02 sensor wire is sheilded about half of the length of the wire. If the fire melted the sheild core to the signal wire it woudl short straight to ground causing this code. Id check that before spending money on an ECU.
Old Jul 22, 2003 | 09:34 PM
turbotime's Avatar
guess i should have clarified... after the fire the entire harness was replaced with a new one. So there are no longer any melted wires. The shop i took it to said they "thought" the ecu was fried becuase the ECT wasnt putting out proper voltage, but they werent sure. Its night here but ill measure the voltage coming from the white wire tommorrow. What should i do to check the voltage? Warm it up and then check it at idle and then above 4k? What should i be getting?
Old Jul 25, 2003 | 01:07 PM
turbotime's Avatar
ok i just put in a new cluster and before i even start the car the temp goes to full H. Is this a sign of bad ecu?
Old Aug 9, 2003 | 05:37 PM
cxSHOE's Avatar
hey turbotime
ive emailed you, ive IMed you, for the past 3 weeks, with on answer from you, i hope you are enjoying the 12 service manuals i sent to you to host for everyone.
you better change your name because everyone will know what a liar you really are.. and dont bother IM me its too late.....enjoy.. and other h-t members watch out for this guy, he is a total liar.....
andyvaj
May 2, 2007 06:28 AM
draxxus07
Sep 29, 2005 11:35 AM
kapoosh valve
23
Jul 1, 2005 09:02 PM
Shakes
Apr 28, 2004 08:45 PM
Eresuncabron
Jan 24, 2004 06:18 AM
