fuel delivery on a turbo crx.....
Old Jul 22, 2003 | 05:29 PM
jdmcrx1's Avatar
Default fuel delivery on a turbo crx.....
I am having trouble figuring out what to use... I am runnning a t3 off a mx6 a fmic and I got a field's sfc-vtec controller... I am wondering, should I get 450's or go with the 390's I have? that is the onlything I have to figure out. any help would be appreciated. Thanks, Tony
Old Jul 22, 2003 | 07:39 PM
xci_ed6's Avatar
Default Re: fuel delivery on a turbo crx..... (jdmcrx1)
I say go w/ the 390s for now, but buy some 450s right away and swap them ASAP. Also keep the boost low when on the 390s, I think you can do around 8 max, but I can't remember and I don't want to do the math.
-Dustin
Old Jul 22, 2003 | 07:44 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcrx1 &raquo;</TD></TR><TR><TD CLASS="quote">I am having trouble figuring out what to use... I am runnning a t3 off a mx6 a fmic and I got a field's sfc-vtec controller... I am wondering, should I get 450's or go with the 390's I have? that is the onlything I have to figure out. any help would be appreciated. Thanks, Tony</TD></TR></TABLE>
Keep the 390's because you can only do +/- 30% with the sfc unlike the +/-50% with the v-afc. You will more then likely be runing to rich if you swap to 450cc injectors.
Old Jul 22, 2003 | 07:45 PM
b16ahybrid's Avatar
Default Re: fuel delivery on a turbo crx..... (b16ahybrid)
BTW where did you get 390's? I'm looking for some 390's for my set-up rite now i'm runing 310's
Old Jul 22, 2003 | 07:57 PM
jdmcrx1's Avatar
what do u think the t3 will run stock? it says it'll run 6-8psi but I have a friend's t25 on a 4door and it is at 10 psi stock...he has the afc hack.. another question, do yu think I will have an ecu code on the sfc? do you guys have any settings for the sfc so I don't have to dick with it?... I won't get any pinging witt the 390's do ya? thatnks for all the help in advance...Tony also, I got the 390's in town,,, if u want them, find me an apexi safc and I will givem to ya if u trade me a safc for the sfc I have.
Old Jul 22, 2003 | 09:28 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcrx1 &raquo;</TD></TR><TR><TD CLASS="quote">what do u think the t3 will run stock? .</TD></TR></TABLE>
Depends on what it came off of and what the the wg is set at. Most likely 5-6psi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcrx1 &raquo;</TD></TR><TR><TD CLASS="quote">.. another question, do yu think I will have an ecu code on the sfc? do you guys have any settings for the sfc so I don't have to dick with it?....</TD></TR></TABLE>
thats not going to cut it, although it will get you close you will still need to tune it properly on a dyno, every car is different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcrx1 &raquo;</TD></TR><TR><TD CLASS="quote">I won't get any pinging witt the 390's do ya? .</TD></TR></TABLE>
Depends on your tuning, I don't get any pinging but thats because i've spent some money on getting it tuned properly. I used to get some pinging but fixed it with a btm. pinging can be caused by several things. Of those to much timing will cause it and to low of octane, runing lean will also cause pinging. Make sure those are all in check and you should be good
LsDecepticon
Jan 14, 2008 02:50 PM
Bartman201
Sep 3, 2005 09:39 AM
NOSED_CRX_VTEC
Aug 15, 2003 01:54 PM
89sib16
Jun 9, 2003 08:46 PM
racinskittle
May 12, 2003 11:18 AM
