Pressure on SAFC going to positive ;)
Hey guys, I noticed today that under boost my pressure reading changes from - to +. It went up to +0.05, and the measurement changes. Anyone know what that means? Is it sensing boost?
I keep a sheet like this handy in my car, the VAFC's readings are in kg/cm^2 not BAR.
VAFC Reading(kg/cm^2) = PSI
.035 = 0.5psi
.070 = 1.0psi
.105 = 1.5psi
.141 = 2.0psi
.176 = 2.5psi
.211 = 3.0psi
.246 = 3.5psi
.281 = 4.0psi
.316 = 4.5psi
.351 = 5.0psi
.387 = 5.5psi
.422 = 6.0psi
.457 = 6.5psi
.492 = 7.0psi
.527 = 7.5psi
.562 = 8.0psi
.597 = 8.5psi
.633 = 9.0psi
.668 = 9.5psi
.703 = 10.0psi
.773 = 11.0psi
.843 = 12.0psi
.914 = 13.0psi
.984 = 14.0psi
1.00 = 14.23psi
.035 = 0.5psi
.070 = 1.0psi
.105 = 1.5psi
.141 = 2.0psi
.176 = 2.5psi
.211 = 3.0psi
.246 = 3.5psi
.281 = 4.0psi
.316 = 4.5psi
.351 = 5.0psi
.387 = 5.5psi
.422 = 6.0psi
.457 = 6.5psi
.492 = 7.0psi
.527 = 7.5psi
.562 = 8.0psi
.597 = 8.5psi
.633 = 9.0psi
.668 = 9.5psi
.703 = 10.0psi
.773 = 11.0psi
.843 = 12.0psi
.914 = 13.0psi
.984 = 14.0psi
1.00 = 14.23psi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beta13 »</TD></TR><TR><TD CLASS="quote">I keep a sheet like this handy in my car, the VAFC's readings are in kg/cm^2 not BAR.
.035 = 0.5psi
.070 = 1.0psi
.105 = 1.5psi
.141 = 2.0psi
.176 = 2.5psi
.211 = 3.0psi
.246 = 3.5psi
.281 = 4.0psi
.316 = 4.5psi
.351 = 5.0psi
.387 = 5.5psi
.422 = 6.0psi
.457 = 6.5psi
.492 = 7.0psi
.527 = 7.5psi
.562 = 8.0psi
.597 = 8.5psi
.633 = 9.0psi
.668 = 9.5psi
.703 = 10.0psi
.773 = 11.0psi
.843 = 12.0psi
.914 = 13.0psi
.984 = 14.0psi
1.00 = 14.23psi</TD></TR></TABLE>
EXACTLY what I was looking for, thank you sir
.035 = 0.5psi
.070 = 1.0psi
.105 = 1.5psi
.141 = 2.0psi
.176 = 2.5psi
.211 = 3.0psi
.246 = 3.5psi
.281 = 4.0psi
.316 = 4.5psi
.351 = 5.0psi
.387 = 5.5psi
.422 = 6.0psi
.457 = 6.5psi
.492 = 7.0psi
.527 = 7.5psi
.562 = 8.0psi
.597 = 8.5psi
.633 = 9.0psi
.668 = 9.5psi
.703 = 10.0psi
.773 = 11.0psi
.843 = 12.0psi
.914 = 13.0psi
.984 = 14.0psi
For those who
A quick way to translate kg/cm2 into psi, is to multiply it by 14.
That will give you a more than accurate enough reading.
ex: .5kg/cm2 * 14 = 7psi
I used to always use the calculator on my Nokia to figure out my boost while
driving. After a week of looking at it though you get used to it, so its pointless
to even convert it anymore.
FastNFurious
Feb 27, 2004 07:45 PM
