h23 ?? crx??
Old Jul 21, 2003 | 08:04 PM
uszcrx's Avatar
Default h23 ?? crx??
well fill me in here? :-) is this even worth it? is it the same install?? I wanna do something different? someone fill me in on all info if they could.. nothing found in the search
Old Jul 21, 2003 | 08:10 PM
SIRX's Avatar
Default Re: h23 ?? crx?? (uszcrx)
IMHO it's WAY to much work. I've never really researched it but what I have read in some topics is it's a major PITA
Old Jul 22, 2003 | 05:02 AM
uszcrx's Avatar
anyone else? Is that .1 difference big?? any details
Old Jul 22, 2003 | 05:16 AM
Mr Furball's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uszcrx &raquo;</TD></TR><TR><TD CLASS="quote">well fill me in here? :-) nothing found in the search</TD></TR></TABLE>
If you did a search, you are a morron, I went in search and all I typed is h23 and I found 823 topics
here are a few
https://honda-tech.com/zerothread?id=551432
https://honda-tech.com/zerothread?id=553626
https://honda-tech.com/zerothread?id=553908
https://honda-tech.com/zerothread?id=542308
https://honda-tech.com/zerothread?id=553737
https://honda-tech.com/zerothread?id=346368
https://honda-tech.com/zerothread?id=552063
https://honda-tech.com/zerothread?id=551508
https://honda-tech.com/zerothread?id=544962
https://honda-tech.com/zerothread?id=543868
https://honda-tech.com/zerothread?id=427499
https://honda-tech.com/zerothread?id=455403
https://honda-tech.com/zerothread?id=542964
https://honda-tech.com/zerothread?id=542421
https://honda-tech.com/zerothread?id=540993
https://honda-tech.com/zerothread?id=514381
Old Jul 22, 2003 | 07:05 AM
Aron Parsons's Avatar
Default Re: h23 ?? crx?? (FURBALL B-16)
Old Jul 22, 2003 | 09:08 AM
uszcrx's Avatar
wow retard.. NOT EVEN one of those posts has anything to do what i'm asking.. i wanted to know if installation into a CRX is alot different from the h22.. as far as positioning , weight , PITA, I said i already searched.. why don't you take your negative and pointless comments elsewhere... BACK TO THE SUBJECT..
I want to do something different .. i know the h23 is still a torque monster compared to the B's and h22 is a little too crazy :-D hah anyone know about this at all??
Old Jul 22, 2003 | 10:13 AM
Mr Furball's Avatar
[QUOTE=uszcrx]wow retard.. NOT EVEN one of those posts has anything to do what i'm asking.. [QUOTE]
Did you check the other 800 posts, ***, it's called research, takes time and I guess you just don't want to put in the work to research the 800 topics to see if there is a posts that tells you what you want.
Old Jul 22, 2003 | 10:52 AM
Racer613's Avatar
When I recieved my Place Racing weld in mount housings and my motor mounts and cutting utensil and all the other ****...in the paperwork it said that "these mounts can be used for the h22 or h23, so they are the same install as far as I know...
Old Jul 22, 2003 | 11:13 AM
hybridbmw's Avatar
Default Re: (Racer613)
It's the same install as a H22 minus the vtec. The swap can be compared to a B18b vs B16. Both engines use the same mounts, however one needs to be wired for vtec and the other does not.
I have seen a H23 turbo CRX close to where i live in FL, the car was very sick .
If you wanna have some fun, drop a vtec head on the H23 block.
Old Jul 23, 2003 | 02:49 PM
uszcrx's Avatar
thank you honda-tech :-) thats all it takes !! for you guys that post search.. the time you post that you could have answered my question thanks tho.. i really couldn't find the info anywhere else
Old Jul 24, 2003 | 08:01 AM
2point6's Avatar
What do you want to know about doing this? I just finished an h22 in a CRX, the h23 is the same thing (instalation wise)
Old Jul 24, 2003 | 09:08 AM
uszcrx's Avatar
a Good write up :-)? i've mostly only found bits and pieces of the whole swap nothing really great.. as of right now i'm looking for anything of the sort h22 h23 f22 .. whatever i can get a good deal on.. hopefully swapping the end of august.. if anyone has any pointers.. or definety DO's and DON'ts because this is gonna be costing me alot ! especially if i do a lot of Don'ts hah.. thanks
Old Jul 24, 2003 | 10:19 AM
insanityworks's Avatar
if u are using it for a drag car u will be fine but if u want it for stree/drag, i would say no, unless u are gona dump a whole lota money into suspension, u are dona need a LSD tranny, and if u dont do suspension, stay away from high speed corners
F22Prelude21
Aug 24, 2006 01:01 PM
2XS
Oct 6, 2004 01:29 PM
GZERO
Sep 22, 2003 03:31 PM
b18josh
Oct 25, 2002 09:39 AM
