JDM motors pass smog?
Old Aug 3, 2001 | 02:30 AM
brad.'s Avatar
Default JDM motors pass smog?
well i got my swap in April...its a b16a1
i've been hesitating to smog it because someone told me that JDM motors won't pass regardless.
any info?
Old Aug 3, 2001 | 02:16 PM
wuhungsixxx's Avatar
New User
Default Re: JDM motors pass smog? ([626]JDM-b16a-EF9)
im sure that u can pass the actual tail pipe test if u have a good cat and ur motor is running correctly...problem is the visual test...der gonna know that the motor isnt suppose to be there...when they put in the #s the motor wont come back stolen since its JDM...if all smog equipment is hooked up the only problem is u sneaking it by as a 94 or newer USDM b16...like the ones from the del sols and 99-00 si...the motor stamping on ur block is different from urs which is from the JDM CRXs...best u can do i would say is hope u get a cool ref...oh by the way in order to get it done at any ol' smog station if u have a drop is to get it BAR stickered from the smog refs...after that no one can touch u...supposedly
Old Aug 5, 2001 | 10:31 PM
WONG FRIED RICE's Avatar
Default Re: JDM motors pass smog? (wuhungsixxx)
Hmm...i have the same dilema...except i went and smogged it already...i passed visual...but the sniff....i failed miserably...i put...USDM Type R headers, factory type R intake, cam gears adjusted back to 0, factory exhaust, and random tech cat....still didn't pass...any ideas??
Old Aug 6, 2001 | 10:28 AM
New User
Default Re: JDM motors pass smog? (JDMB16ACRX)
...jeez didnt pass huh...i take it u went to a ref station correct?...i would of guessed it had some thing to do with ur cat but since u have a new one....dunno...and u passed the visual so everything gotta be connected...so it could still be the type r cams thats causin the problem...but tell u the truth i really dont know...i have yet to attempt the smog yet...all i know is from what iv learned from others and this forum...try hybridhonda.com and search for smog refs...i believe there was a guy on der that also passed vissual but not tail pipe...and i do remember he solved the problem...im sure there also has to be someone here that knows...try the hybrid forum too....sorry if i wasnt much help...good luck tho
Old Aug 6, 2001 | 10:31 AM
New User
http://hybrid.honda-perf.org/
sorry this is the site
Old Aug 6, 2001 | 10:33 AM
dustin's Avatar
I just got an '88 CRX w/ a ZC motor. Any idea how I should handle smog for it? Tags expire in november.
Dustin
Old Aug 6, 2001 | 10:52 AM
New User
here i pulled some hints from that web site i posted earlier...
Hints:
#1 Pick your engine model and year. Its safest to pick the actual year of your engine, but regardless, the engine year you state must be the same year or newer than your car. For example, 95 Integra GSR, or 95 Del Sol VTEC, into a 88-95 Civic.
#2 Make sure your engine configuration and vacuum line configuration match the US Helms manual of the engine you claim to have. Nothing should be missing and everything should be as shown in the manual. And the locations of the parts need to be very close to the manual. In other words, if you are converting a 96 GSR engine to 95 spec, you must be certain you get all emissions parts right. If you have a Japanese engine, you still need to make sure the emissions parts and hoses match the US version you are smogging as.
#3 A receipt for your engine can smooth things over, if its a US engine.
#4 Make sure your car is running clean: new plugs, plug wires, cap and rotor. Good O2 sensor, and a good cat are essential.
#5 Don't bother trying to pass a stolen engine.
Old Aug 6, 2001 | 10:58 AM
New User
Default Re: JDM motors pass smog? (dustin)
dustin-
hey sorry to tell u this but u cant pass a ZC motor LEgally...u cant sneak it by because they never had a ZC motor in the states...u can always try to find a smog station to ignore the motor...but they will charge u hella bank cuz its illegal...or if u wanna go throught the trouble...iv heard people swaping the ZC out and putting back the stock motor just for the smog and then out goes the stock and in goes ZC power..hehe...sorry i doubt theres anyway easy way around it(legally of course)
Old Aug 6, 2001 | 11:59 AM
hmm...aite man...thanx for the info tho...i'll check out the site...see if i can find some ideas...and let you guys know what happens next time i smog!!
Old Aug 7, 2001 | 12:12 PM
dustin's Avatar
Hmm I have the original motor but I am not sure whether it runs.... Swapping it out will be a BIG pain. Bah, this sucks.
Dustin
Old Aug 7, 2001 | 12:36 PM
brad.'s Avatar
geez....damn JDM motors....so much power...but
NOT LEGAL
...i hate California
Old Aug 7, 2001 | 01:06 PM
dustin's Avatar
California DOES suck. I hate it here.
Dustin
Old Aug 7, 2001 | 03:32 PM
New User
Default Re: JDM motors pass smog? (Teken)
yea cali sucks **** in terms of trickin up rides due to smog laws...ironic how cali also has probably the largest population of trick imports too....
Old Aug 8, 2001 | 01:22 AM
brad.'s Avatar
yeah i know...well there's no ticket for ugly bodykits
guamie
Nov 2, 2006 08:50 PM
IgniteTeg
Apr 23, 2003 09:12 PM
Dashu
Oct 28, 2002 10:16 PM
trix are for kids
Jun 4, 2002 09:09 AM
YellowCivic95
Apr 18, 2002 06:13 PM
