Put back motor....started it up....OIL EVERYWHERE!
Old Jul 20, 2003 | 06:33 PM
Poop111444's Avatar
Default Put back motor....started it up....OIL EVERYWHERE!
Setup: STock 99Si T3 turbo, 9 psi, VAFC controlling 450cc injectors
Due to my leanness of the VAFC (i had it set to -37% in the higher RPM band ), the car ended up cracking 1 ringland. So i went ballz out and into the motor and replaced it. Bolted everything back together to spec, put on the new T3/T04 turbo, and before we put in the spark plugs, we wanted to make sure we got oil pressure to the turbo. Well, without the plugs in, the car didn't create oil pressure. So we threw in 2 spark plugs and got it to start. Oil came out of the feed line. Great.
But then a puddle of oil was spewing around the oil filter! Drippin everywhere! I was like huh? So I checked the oil filter, and it was on good, no double gasket or anything. So i cleaned it up, we started again while I was under the car. It started to seep down on this black box right near the oil filter.
This black box (oil breather chamber) has two hoses going to it....well, i noticed it was unplugged after the intake manifold was put on, so i kinda just barely put it in. I couldn't get a vicegrip on the hoseclamp, but i thought it was vacuum canister or something along that line.
Im 99.99% sure its not coming from the headgasket, but im pretty sure it looks like its coming from this oil breather chamber...I just thought it had oil vapors flow into it, but it looks like it has a good amount of oil pressure in there?
Does this sound right? TOmmorow i think i'll take off the intake and make sure that thing is on good. Other then that everything went well.
Old Jul 20, 2003 | 08:28 PM
b18cx's Avatar
Default Re: Put back motor....started it up....OIL EVERYWHERE! (si_mekanik)
First thing I would check is to see if you cracked the nipple coming off the block where you probably taped in for oil feed.
Old Jul 20, 2003 | 08:31 PM
lazerus's Avatar
Default Re: Put back motor....started it up....OIL EVERYWHERE! (b18cx)
also, from blowing the ringland, it puts oil into most every vacuum hose (or can anyway)
Old Jul 20, 2003 | 08:47 PM
GsrSol's Avatar
as stated above, oil feed line into the block should have been the first thing to check.
Old Jul 20, 2003 | 08:54 PM
CRXRageD's Avatar
ew, that sucks.
Old Jul 21, 2003 | 04:26 AM
Poop111444's Avatar
Default Re: Put back motor....started it up....OIL EVERYWHERE! (CRXRageD)
The oil feed line is bone dry. I just didn't think the oil breather chamber had a lot of oil pressure going to it. Im quite sure this is the problem though. We will find out tonite.
Old Jul 22, 2003 | 05:12 PM
b18cx's Avatar
So what heppened?
Old Jul 22, 2003 | 06:14 PM
Poop111444's Avatar
I figured it out.
Headgasket was on upside down
Live and learn I guess. but i was really easy to take off now. Now i wont make that mistake again.
Old Jul 22, 2003 | 07:20 PM
romeo619romeo's Avatar
i guess the .1% proved you good recovery tho
Maiyen
13
Dec 26, 2017 04:20 AM
adictionbass
Mar 24, 2006 12:44 PM
_gurusan_
Dec 20, 2005 10:41 AM
*Boostwerks*
Jun 11, 2005 05:18 PM
JPowers
Feb 17, 2003 08:16 PM
