I have a problem
Old Jul 20, 2003 | 04:30 PM
xxthabest1xx's Avatar
Default I have a problem
I JUST PUT A SWAP IN MY CAR BUT WHEN I TAKE MY RPM TO HIGH THE TEMP GAUGE GOES UP LIKE AN RPM GAUGE I HAVE NO IDEA WHATS CAUSING THIS PROBLEM CAN SOMEONE HELP.. PLEASE
Old Jul 20, 2003 | 04:32 PM
mmuller's Avatar
Mad Scientist
Default Re: I have a problem (xxthabest1xx)
hugh???? elaborate better, it goes up and down with the rpm gauge? or it just gets hotter when at high rpm?
please read the forum guides about CAPS LOCK
Old Jul 20, 2003 | 04:44 PM
Pho Real's Avatar
Default Re: I have a problem (mmuller)
You also have another problem with yelling.
Old Jul 20, 2003 | 06:56 PM
AllmotorJunkie's Avatar
you might have a loose ground somewhere in your engine bay.
I had a similar problem but mine had to do with the RPM skyrocketing to 10,000 RPM.....
Old Jul 21, 2003 | 01:03 PM
Default Re: I have a problem (AllmotorJunkie)
i checked for ground no loose ground, i nned a tps sensor but i doubt its cause of that, any ideas...
Old Jul 21, 2003 | 02:08 PM
Audi RS4's Avatar
Lover
what engine did you swap in? what car did it go in? what ecu? did you swap the cluster gauge? be more specific newb..................
Old Jul 21, 2003 | 03:45 PM
Default Re: I have a problem (AK1200)
i blew the motor on my gsr so i put another gsr, rpm goes crazy after 7000 rpm and the car still heats up, i took off my thermostat, still heats up, i double check the wiring to make sure everthing is plugged in right, still heats up, and rpm goes crazy still , everthing is the same as when i had the other motor. only different new motor.
Old Jul 21, 2003 | 06:11 PM
NonovUrbizniz's Avatar
Loved
bad sensors on the new block.
Old Jul 22, 2003 | 07:32 AM
Default Re: I have a problem (NonovUrbizniz)
what sensor can be causing it.
Old Jul 22, 2003 | 10:54 AM
Loved
well it could be the temperature sensor...
but I'd be damn sure you're not actually overheating first...
nychonda
Aug 22, 2012 10:38 AM
madriagax619
Aug 22, 2009 05:46 AM
myhatch98
Dec 8, 2005 09:24 PM
Methane2k2
Aug 3, 2005 10:39 PM
