Skunk2 Camshaft Problem
For the past couple of hours my uncle has been trying to install my camshafts for me. The car idles like crap and then dies. We are having no luck at all here. I have directions from three different websites. Can someone please help me. We are so lost here and I have been searching for the past two hours. PLEASE HELP!
Well if I hit the gas it revs up ok but then when you let off it idles rough, starts to idle faster then just shuts off. No I wish, but they are just stage 1's. Its also starting to smoke a good bit as well. Were pretty sure its TDC
My uncle says the distributor is having no effect on the engine what so ever???? Can anyone else give me any ideas or any other sites to look at, I am so lost and dissapointed........
Modified by cyphergs-r at 10:15 AM 7/20/2003
Now my belt is slipping off my cam gears, it seems to jump a little bit. It looks like the intake cam gear is getting to much stress and then it jumps a little off the exhaust cam gear. Now what the hell is going on here????
To get it TDC you are suppose to stick screw drivers in the slots of the camshafts, and look at the cam gears dots and make sure they are both facing eachother correct? Well when this happnes we put the screw drivers in the camshafts and the exhaust cam is one tooth off, and the belt jumps off the exhaust cam.
Gump
14
Apr 27, 2004 08:40 PM
