Car stutters!
Old May 18, 2003 | 07:31 AM
slowman's Avatar
I took way too long
Default Car stutters!
OK, I changed my cam in the D16A6. Replaced it with a Crane Stage 2 about 4-5 months ago. Whenever I'm going and then when I slow down coming up to turn from one road to another and I sort of stop but keep on rolling when I see that it's clear and hit the gas. Not flooring it just on the gas normally to get going again, it studders like a crazy **** as if it was hitting a rev limiter set at 3,000 RPM or something. Then after a few it's OK. It's not like sometimes it does this and sometimes it doesn't, it's ALL THE DAMN TIME! It really makes daily driving a bitch and would like to get it so it will NOT do this. I have a skunk2 adjustable cam gear so maybe if I turn it one way or another it would help? IDK anymore, any of you got an idea on what's up?
TIA
Old May 18, 2003 | 02:07 PM
4DeepCivic's Avatar
Default Re: Car stutters! (GSRjohnny)
Check for vacuum leaks, cam timing, ignition timing, fuel pressure, ignition (dist)
Just my $.02
Old May 19, 2003 | 06:01 AM
DragonTLS's Avatar
Default Re: Car stutters! (johnny s.)
did you install the timing belt correctly or adjust the timing belt tensioner
cruzthestreets
Sep 17, 2014 11:01 AM
PINKS
Aug 9, 2006 02:44 PM
PINKS
Aug 9, 2006 02:22 PM
mikester_91
Feb 14, 2005 07:45 PM
carcala
Jan 18, 2003 04:06 PM
