help! S-AFC base settings 90 Integra
Old Jul 19, 2003 | 02:57 PM
TRAY's Avatar
Default help! S-AFC base settings 90 Integra
Just got finished installing a S-AFC on my 1990 Integra but I dont understand the settings for my car can someone help me out....thanks!
Old Jul 19, 2003 | 03:29 PM
TRAY's Avatar
Default Re: help! S-AFC base settings 90 Integra (TrayDay2K1)
OK heres what I did so far:
1) I went to misc. and set the sensor type to pressure
2) I set the # of cyl to 4...what do I set the throttle sensor type setting to? Arrow up or down?
3) I set the sensor #'s to 6 in and out...is this right?for PR-6???
help im lost!!! and I want to go to the track to watch the races!!!
EDIT: what else do I need to do to make it run like stock until I install my turbo...Thanks in advance
Old Jul 19, 2003 | 04:05 PM
TRAY's Avatar
ahhhhh!!!
Old Jul 19, 2003 | 10:10 PM
TRAY's Avatar
anyone??? Show me the light!
Old Jul 20, 2003 | 12:10 AM
TRAY's Avatar
ok i re-wired it and got the same prob....heres what I think now...when you look at the wiring diagram for the afc do you match it to the front or the back of the ECU plug...I matched it to the front but i think I may have to match it to the back.....help!!!!
Old Jul 20, 2003 | 03:27 AM
kpt4321's Avatar
Is the unit even coming on? If the unit is coming on, then you are looking at the correct side of the plug.
You want to set it up for MAP (pressure), 4 cylinder, and the correct throttle type.
You have one sensor in, and one sensor out.
Old Jul 20, 2003 | 10:04 AM
TRAY's Avatar
Default Re: (kpt4321)
the unit is comming on, but i checked the lead I had it wired to and its hot just like the wire is if i plug it in backwards....when I rev the motor a little it turns on and off...i definetly wired it wrong...now I have white smoke comming out of my exhaust i think I blew the headgasket somehow with my messed up wiring...im gonna shoot myself!
Old Jul 20, 2003 | 09:02 PM
TRAY's Avatar
Default Re: (TrayDay2K1)
ttt
2civic3
Sep 22, 2006 09:34 PM
madlion
Sep 19, 2004 08:36 AM
Integra808
Apr 30, 2003 05:47 AM
Speedz
Aug 13, 2002 06:26 PM
zexdrex
Jun 14, 2002 04:34 PM
