safc
Old Jun 14, 2002 | 11:24 AM
zexdrex's Avatar
Default ???????safc???????
i just installed the safc on my 90 crx w/zc and i had it in the monitoring mode and noticed that the rpms are off a bit anyone else notice that also i get NO pressure reading i called apexiusa and they said hondas dont give pressure reading i just wanted to know if anyone else noticed this
thanx
[Modified by zexdrex, 8:24 PM 6/14/2002]
Old Jun 14, 2002 | 03:17 PM
GTM's Avatar
GTM
Default Re: ???????safc??????? (zexdrex)
All Hondas operate using speed-density i.e. MAP sensor. You should, in fact, get a pressure reading but the numbers will be negative until you reach full throttle, where you should get a zero reading.
As for the RPMs being off check your settings, namely the number of cylinders. It shoud be 4 (hopefully) and the arrow should be pointed up.
I believe you just didn't play with the initial settings on the S-AFC. Make sure the thing is set for your car and as a last note, make sure the that sensor type is correct. Best thing to do is bring it to an experienced tuner who has experience setting the AFCs.
Good luck, and let me know if you have any questions.
Old Jun 14, 2002 | 04:34 PM
inspyral's Avatar
Default Re: ???????safc??????? (GTM)
sensor type should be 6 in, 6 out, I believe...
2civic3
Sep 22, 2006 09:34 PM
-JSpecEk*9-
22
Jun 8, 2006 02:26 PM
Revi
Jul 9, 2004 10:00 AM
rlrhett
Apr 4, 2004 12:00 PM
_Endless_
May 16, 2003 06:24 PM
