Head Count (How many of you had to replace your head gasket)
Old Jul 19, 2003 | 11:30 AM
TypeR 01 886's Avatar
Default Head Count (How many of you had to replace your head gasket)
Just curious. I have to replace it now in my ITR. They found a leak. I also had to do this with my GSR when I had it at about the mileage im at with my ITR.
2001 36+k
Old Jul 19, 2003 | 11:43 AM
B2FiNiTY's Avatar
Default Re: Head Count (TypeR 01 886)
I almost had to but end up not being the problem thank goodness.
Old Jul 19, 2003 | 01:16 PM
.RJ's Avatar
.RJ
are you sure its not the cam cover seal or cam end seal(s)?
Old Jul 19, 2003 | 02:04 PM
Default Re: Head Count (.RJ)
nope, looks like it coming from head gasket. it not that big of deal
Its under warranty
Old Jul 19, 2003 | 03:29 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 01 886 &raquo;</TD></TR><TR><TD CLASS="quote">nope, <u>looks</u> like it coming from head gasket. it not that big of deal
Its under warranty</TD></TR></TABLE>
Important word highlighted. Its probably a cam or cam cover seal.
Old Jul 19, 2003 | 03:31 PM
Philly_NBP_R's Avatar
62K miles here and no sign of this problem... If you pull off the valve cover, make sure you put a little sealant around the cam covers before replacing cover - this is a common oil leak source for all B series blocks.
Old Jul 19, 2003 | 10:38 PM
Default Re: Head Count (Philly_NBP_R)
thank guys again for all the help!!
Old Jul 20, 2003 | 06:28 AM
jond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 01 886 &raquo;</TD></TR><TR><TD CLASS="quote">it not that big of deal Its under warranty</TD></TR></TABLE>
Correct me if I'm wrong. If the head gasket blows, antifreeze mixes with your oil, and your engine will be completely worthless in less than 1000 miles right?
Old Jul 20, 2003 | 10:12 AM
98itR484's Avatar
Default Re: Head Count (jond)
i've replaced my headgasket...but there was nothing wrong with it when i replaced it
Old Jul 20, 2003 | 03:10 PM
fowler!'s Avatar
Default Re: Head Count (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">I almost had to but end up not being the problem thank goodness.</TD></TR></TABLE>
What ended up being the problem Dennis?
Old Jul 20, 2003 | 03:29 PM
GokuSSJ4's Avatar
Default Re: Head Count (fowleryo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fowleryo &raquo;</TD></TR><TR><TD CLASS="quote">
What ended up being the problem Dennis?</TD></TR></TABLE>
his cams installment j/k ....
Old Jul 20, 2003 | 08:59 PM
fowler!'s Avatar
Default Re: Head Count (Spoon1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon1 &raquo;</TD></TR><TR><TD CLASS="quote">
his cams installment j/k ....</TD></TR></TABLE>
fuggin Pep Boys!!
Old Jul 20, 2003 | 09:29 PM
Dave-ROR's Avatar
lol was that the rachet still attached to the crank pulley incident?
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
Important word highlighted. Its probably a cam or cam cover seal.</TD></TR></TABLE>
I agree with this.
Old Jul 20, 2003 | 09:39 PM
SpoonSpecR's Avatar
Default Re: Head Count (FizzleDaKlown)
What were your symptoms? How did you know it was going...
Old Jul 20, 2003 | 10:54 PM
B2FiNiTY's Avatar
I can't believe people still remember that pep boys thread. The leak turned out to be one of the oil seals on the cams, cam gear side. Just like Trey had. Replaced and no more problems too date.
Old Jul 21, 2003 | 04:52 AM
Haunt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">I can't believe people still remember that pep boys thread</TD></TR></TABLE>
It was funny...
I would check out the seals on the cams...more than likely that is your problem.
Old Jul 21, 2003 | 06:37 AM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">I can't believe people still remember that pep boys thread.</TD></TR></TABLE>
What was it? last year? that's "new" honda-tech
Old Jul 21, 2003 | 03:23 PM
MackSpeed-616's Avatar
i think i probably went through about 10 or 12 head gaskets in the 3 years i owned my ITR
Old Jul 22, 2003 | 06:33 AM
RTW DC2R's Avatar
Default Re: Head Count (MackSpeed-616)
I thought I had a leak as well. Pulled the head and replaced the gasket 2 times, then realized it was either the distributor O ring, or a cam seal live and learn I guess
Old Jul 22, 2003 | 07:57 AM
Asahi's Avatar
Default Re: Head Count (RTW DC2)
If it is an oil leak and looks like the headgasket . . . it isn't. RJ is most likely right. More likely a cam seal.
Old Jul 22, 2003 | 10:19 AM
Austin's Avatar
Replaced the head gasket, but not because it needed replacing, and the leaking oil is most likely from somewhere other than the head gasket. As stated above you're looking at the valve cover gasket, the cam seal, or the distributor(not sure on this one).
Austin
2muchPSI
Jun 1, 2020 01:28 PM
burch-eg6
Feb 23, 2011 12:25 PM
patrickstar
19
Feb 16, 2010 06:48 AM
redintheface
May 27, 2003 10:40 AM
sivik2nr
Nov 26, 2002 12:30 PM
