Where's the leak coming from
I noticed taht every few days, there is some oil on the front side of my engine...specifically over the area where the engine code is... could the leak be coming from the head gasket? I don't know where else it could be coming from... man i hope its not that... I don't wanna really do that right now.. never done it before, and it's getting winter here...
Could that be where it's coming from?
Re: Where's the leak coming from (Spade)
valve cover gasket or exhaust cam seal
i just did a topic on this if you search for it im sure it can help you it has pics of excatly what you described
Re: Where's the leak coming from (sivik2nr)
if you took off the valve cover did u remember to use thye silicone sealent in the whooops over the cam seals?
or did u replace the cam seal?
cam seal or vtec solenoid gasket. check those first before you take the head off. clean the engine really well and then check it in a few days and see where its coming from.
keith
keith
Re: Where's the leak coming from (kwil666)
Yeah, the leak is from the cam seals.. i didn't start till i removed the valve cover. Is it just not tight enough?
or do i replace the seals?
raverx3m
14
08-31-2013 05:53 PM
patrickstar
19
02-16-2010 06:48 AM
