blown headgasket
Old Jul 19, 2003 | 10:16 AM
jweller's Avatar
Default blown headgasket
99 Accord F23A1
OK my head gasket blew, massive ammounts of oil in my coolant, but no real signs of coolant in my oil. I pulled the head and I checked for warpage with a straightedge. no signs of it though spark plugs and exhaust valves are white though. so they are definately too hot.
could the excessive heat cause the headgasket to blow without warping the head?
Should I get the head machined anyway? I need the car monday to go to work and I doubt I'll be able to find somebody to do it between now and then, so I'd rather not if it's safe.
Old Jul 19, 2003 | 12:49 PM
Blaze45's Avatar
Brrraaaap!
Default Re: blown headgasket (jweller)
If it gets too hot it can warp. It would be safe to mill a few thousands off just to make sure.
Blaze
Old Jul 19, 2003 | 01:04 PM
Fkned2003's Avatar
gaskets blow for a reason if you dont get whatever it was that caused it to blow it will happen again .
Old Jul 19, 2003 | 01:14 PM
TrickHonda98's Avatar
Default Re: blown headgasket (Fkned2003)
well, if you have oil in your radiator coolant, you'd better flush it out. but yes, it can warp.
Old Jul 19, 2003 | 08:40 PM
jweller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fkned2003 &raquo;</TD></TR><TR><TD CLASS="quote">gaskets blow for a reason if you dont get whatever it was that caused it to blow it will happen again . </TD></TR></TABLE>
I know that much, I just don't know why it blew
Old Jul 19, 2003 | 11:10 PM
Fkned2003's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jweller &raquo;</TD></TR><TR><TD CLASS="quote">99 Accord F23A1
I need the car monday to go to work and I doubt I'll be able to find somebody to do it between now and then, so I'd rather not if it's safe.</TD></TR></TABLE> If your telling me that you already knew you had to get it fixed WHY are u asking this question
Old Jul 20, 2003 | 05:26 AM
jweller's Avatar
No, I'm saying that the head doesn't seem warped. I checked it with a straight edge and a feeler gauge like the Helms says to and it's well within spec. I'm asking if a headgasket can blow WITHOUT the head being warped. IF the head isn't warped then there doesn't seem to be any reason to go get it milled, especially since I'll have to take a day off work to get it done.
Old Jul 20, 2003 | 11:31 AM
WangChung's Avatar
look up steel seal on google. my dad owns this company and they have a blown headgasket sealer, its a liquid. its really effective, works everytime.
AllThumbs
14
Jan 2, 2013 11:37 AM
pkjie108
Oct 12, 2006 06:29 PM
whoa its len 2
May 19, 2003 12:20 PM
Halo
Aug 12, 2002 06:27 PM
GSG2
Jul 27, 2001 06:52 PM
