Thrust washer problem
Old Jul 18, 2003 | 08:33 PM
P1mpSlap's Avatar
Default Thrust washer problem
Ok, when I was pulling the pistons out today. I wasn't paying attention and rotated the crank a little too much. One of the thrust washers fell out.
I was able to put it back in, but it sits kinda loose (washer on the oil pump side). The thrust washer on the clutch side sits in there nice and firm.
I noticed that these will not rotate at all and stay in place if the main caps are installed. Well when I pulled the block girlde, the main caps came out with it. (dunno if that's normal) So when I reinstall the main caps/block girlde will the thrust washer on the oil pump side sit firmly and not wabble around?
Old Jul 18, 2003 | 08:46 PM
civicsitek GanGsTa's Avatar
Default Re: Thrust washer problem (P1mpSlap)
just throw some lube on both sides and put it in, it will stay
Old Jul 18, 2003 | 08:50 PM
P1mpSlap's Avatar
Default Re: Thrust washer problem (civicsitek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsitek &raquo;</TD></TR><TR><TD CLASS="quote">just throw some lube on both sides and put it in, it will stay</TD></TR></TABLE>
ROFL
OK. I guess I'm just over analyzing it. If anyone else has input on this situation, please let me know.
Old Jul 19, 2003 | 07:18 AM
owen_the_soyboy's Avatar
SAME HERE.
lubed it up to 'goop' it onto the block and it didnt move (*read: fall on the floor again!)
Old Jan 10, 2005 | 08:02 AM
MyVtec8yourV8's Avatar
Default Re: Thrust washer problem (owen_the_soyboy)
i have this problem on my h22
the one thrust washer closest to the flywheel is all ground up and loose as hell. you can push up on both ends and it moves.... but the other one fits snug and to get it to move you only can push up on one end... is there somethign wrong?
conquer11s
Apr 22, 2007 05:53 AM
dr_latino999
Nov 22, 2006 07:46 AM
( o )( o )
16
Mar 26, 2006 10:48 PM
Natural Aspirations
Feb 6, 2006 05:49 PM
VSM QTK
Apr 21, 2003 01:28 PM
