Think I got into trouble w/this turbo. (vafc, timing, & int. wastgate ?'s)T3 turbo
Old Jul 18, 2003 | 07:36 PM
racinskittle's Avatar
Default Think I got into trouble w/this turbo. (vafc, timing, & int. wastgate ?'s)T3 turbo
Hey guys I need some help. I will be installing the turbo next week if everything arrives on time (otherwise the week after for sure). Im getting really worried. Oh yeah by the way, if Dynomax is reading this, hey, are you busy next week?
My question is this.
I have a .60/.48 60 trim T3 turbo and will be using the int. wastegate. I believe the stock wastegate is set at 10psi. I believe this is too much for my D16z6 right from the start. I know I need to change the spring to lower the boost. Do you know anywhere that sells different springs for my wastegate on my T3?
If not, what are some settings I can set my VAFC to in order to run considerably rich so I dont lean out?
Also, what should I retard my timing to in order to protect my engine?
Setup:
t3 turbo
starion FMIC
450cc injectors on the "hack"
2.5 DP and 3 inch exhaust
2.25 to IC and 2.5 to throttle body
Thanks a lot!
Dan
Old Jul 18, 2003 | 07:39 PM
Boosted LS's Avatar
Default Re: Think I got into trouble w/this turbo. (vafc, timing, & int. wastgate ?'s)T3 turbo (racinskittle
set the afc to -40 from 1-6k rpm then -35 above 6k rpm.
Old Jul 18, 2003 | 07:55 PM
Thanks a bunch! I really appreciate the help.
LOL now i can FINALLY get some decent sleep instead of thinkin about that at night.
Modified by racinskittle at 5:07 AM 7/19/2003
Old Jul 18, 2003 | 08:53 PM
Boosted LS's Avatar
check out thedropshop.tv/vafc they have a little article about it with some helpful pics
jeffsciv23
Nov 14, 2004 06:43 AM
Terrabomb
Jul 16, 2004 11:11 AM
Smooth-GSR
May 3, 2004 03:11 PM
hoya_10fintec
Jun 12, 2003 06:21 AM
mafioso102
Feb 21, 2003 05:37 AM
