converting obd1 to obd2!!!
Old Jul 18, 2003 | 02:34 PM
1man's Avatar
Default converting obd1 to obd2!!!
hey guys, ive found a b18c1 at a very affordable price, however i ran into some problem. The motor im looking at is obd1, and my car is obd2. I heard that u can convert obd1 motor to obd2, and so far i've found obd2 harness, distributor and ecu, what else to i need?
thanx
Old Jul 18, 2003 | 02:43 PM
AzG35's Avatar
Default Re: converting obd1 to obd2!!! (Gin 'n Juice)
To put an OBD1 motor in an OBD2 car, you can do a couple things. The first is convert your ECU to OBD1 (jumper harness, OBD1 ecu). The second is add the necessary stuff to your motor or else it will throw codes. Primarily the CKF sensor which sits on the oil pump and detects the crank rotations. The OBD1 motor doesn't have this. I am not completely sure what you would need to do with it, if its not there, you will throw a code. You will have to convert the plugs on your distributor too, the OBD2 dist only has 1 plug, teh OBD1 has 2. You just have to cut and splice either plug in. Injector plugs are also different on the OBD2 car, you either need to use OBD1 injectors or change the injector clips to OBD1. I can't think of anything else right now. I'm sure someone else will.
Old Jul 20, 2003 | 09:23 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: converting obd1 to obd2!!! (AzSi22)
Why in the world would you EVER want to go backwards? Just get an either an OBDIIa 96-98 or OBDIIb 99-00 (some 98's in there) --> OBDI adapter harness and call it a day. PM Kenji. He's got em for cheap. When my friend did a B16B swap in his SI I know he payed under $200 it. I wanna say $175ish shipped.
Old Jul 20, 2003 | 06:41 PM
B16b2b's Avatar
Default Re: converting obd1 to obd2!!! (Mr Milano)
an obd1 motor plugs right into the obd2 engine harness, then just use the obd1 ecu and jumper harness. works great.
edit* with the exception of distributor and fuel injectors possibly..
Old Jul 21, 2003 | 08:53 AM
AzG35's Avatar
Default Re: converting obd1 to obd2!!! (B16b2b)
It depends what car it is too.
Old Jul 21, 2003 | 09:36 AM
AllMoToRB18c's Avatar
u need a ecu jumper harness...obd2 injectors...obd2 distributor...and a obd2 altenator...and a obd2 wiring harness.....that should be about it.
Modified by AllMoToRB18c at 6:49 PM 7/21/2003
Old Jul 21, 2003 | 10:58 AM
rotaryCIVIC's Avatar
#1 Tool
Default Re: converting obd1 to obd2!!! (AllMoToRB18c)
JUST BUY A ROTARY THEN YOUR LITTLE HONDA GO FAST !!!!!!!!!!!!!!
Old Jul 21, 2003 | 11:09 AM
C_A_T's Avatar
Default Re: converting obd1 to obd2!!! (rotaryCIVIC)
This is a tech forum so contribute, shut up, or get out.
C_A_T
Old Jul 21, 2003 | 11:45 AM
NSX Bob's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rotaryCIVIC &raquo;</TD></TR><TR><TD CLASS="quote">
JUST BUY A ROTARY THEN YOUR LITTLE HONDA GO FAST !!!!!!!!!!!!!!</TD></TR></TABLE>
You're a loser. Mods, please ban this moron, check his posts and you'll see why.
jlowellintegra
Sep 3, 2010 07:34 AM
topherchris
Sep 26, 2007 07:30 PM
ekb16
Feb 15, 2005 06:51 AM
1hotvtec
Oct 12, 2003 07:29 PM
hatchy
Mar 31, 2002 08:24 AM
