high oil pressure good for turbo?
Old Jul 17, 2003 | 11:27 PM
egturbo's Avatar
Default high oil pressure good for turbo?
sup guyz.. i did something and i got a lil higher oil pressure. but now i see smoke out the exhuast.. high oil pressure with a turbocharger bad?
Old Jul 18, 2003 | 02:31 AM
DSF's Avatar
DSF
Default Re: high oil pressure good for turbo? (egturbo)
It's hard to say. 75psi in a -3 line is going to be different than that of a -4 line (volume that is). Maybe some specifics....actual idle/3k+rpm pressure, place of measurement, ets.
Old Jul 18, 2003 | 10:47 AM
egturbo's Avatar
Default Re: high oil pressure good for turbo? (DSF)
umm i dunno i dont have a oil pressure guage. but i know im gettin higher oil pressure. cuz i put a RSX oil filter on.. and that promotes higher oil presssure. but after i put that on i see smoke come out of the exhuast now. but the oil feed line is a small one i dont know the measurements.
Old Jul 18, 2003 | 11:02 AM
RGAZ's Avatar
New User
The filter shouldn't bump up the pressure much at all. but if your drain line is marginally sized and you increase the pressure the high pressure in the center housing could be pushing past the seals.
Either improve your drain line or try a restrictor.
Randy
Old Jul 18, 2003 | 11:20 AM
paulzy's Avatar
Default Re: high oil pressure good for turbo? (RGAZ)
if you're running a -4 line and teh oil pressure is too high, your drain line might not be efficient enough and oil will start seeping out both sides of the turbo
Old Jul 19, 2003 | 11:24 AM
RuthlessEF-9's Avatar
Default Re: high oil pressure good for turbo? (Paul_Vang)
yup thats my problem right now im switching to -3an
Old Jul 19, 2003 | 01:02 PM
hatchback19's Avatar
Default Re: high oil pressure good for turbo? (D16z6turbs)
i talk to ken at cheapturbo.com when i got my turbo.
4an and a restrictor to take it from 75 to 40
Old Jul 19, 2003 | 06:54 PM
pornstarSR's Avatar
Default Re: high oil pressure good for turbo? (hatchback19)
you oil pump should have a bypass at about 80 psi anyways...when the oil is at opperating temp
but as far as turbos go...they dont relaly like high oil pressure, from what i have seen and heard...
my Hks gt turbo has a banjo fitting bolt to feed the oil and it has a restrictor in it...and i was told(from hks) no matter what make sure to use that bolt with the restrictor...it is important..
just some info...it could be different for different things
thanh4o8
May 26, 2009 08:35 PM
BorderM3
Mar 26, 2003 11:22 AM
CzanSOHC
Jan 29, 2003 09:36 PM
vtecsiqt
Jun 17, 2002 07:51 PM
slo blue
May 27, 2002 08:30 PM
