Tools For Engine Building
Old Jul 17, 2003 | 03:14 PM
steve_s's Avatar
Default Tools For Engine Building
Hey guys im looking into building my first engine and would like to know what tools i would need. For example ring compressors or any sory of messuring device, thanks a lot.
Old Jul 17, 2003 | 03:44 PM
poison's Avatar
Default Re: Tools For Engine Building (steve_s)
What exactly are you doing with the motor? There are many tools you need.
Old Jul 17, 2003 | 03:47 PM
steve_s's Avatar
Default Re: Tools For Engine Building (poison)
Just new pistons and conrods to the block and most likely a whole new valvetrain.
Old Jul 17, 2003 | 03:55 PM
altoid's Avatar
torque wrench, ring compressor, ring expander, socket set, breaker bar, rachet (3/8" and 1/2"), manual, possibly a micrometer or caliper depending on if you're using things that need to be stretched and measured, time, patience, the ability to look over everything and check clearances properly, possibly some plastigauges. Trash bags to keep things like your crank and girdle (if you have one) in so they get no dirt on them. Air compressor for sure, Air bush deal so you can properly and effectively blow air on parts to clean them off...A varible speed drill, a hammer, a flex hone which is the proper size to knock the glaze off your cylinder walls. Oil, Lint free paper towels to clean out the cylinders, those little metal strips, whatever the hell they're called to be able to check clearances. I think thats it
edit: if you're doing the valve train you'll need a spring compressor, valve grinding compound. Easy and fast way to remove the **** from the springs is put a socket over the valve you wanna remove the spring from. Hold the socket there, and give it a good wack with a hammer, be careful not to slip and also be ready to catch your little metal doodads that hold the spring down as they might slide off. Easy and fast and effective.
Old Jul 17, 2003 | 04:08 PM
steve_s's Avatar
Default Re: Tools For Engine Building (altoid)
Thanks a lot, thats what i was looking for, i have about half of those tools, i better get shopping.
I beleive those little metal strips are called feeler gauges.
Old Jul 17, 2003 | 04:43 PM
altoid's Avatar
lol yeah i couldn't remember the name, thanks good luck
bluestone
12
Oct 5, 2018 05:16 PM
crazyfiddler
May 27, 2008 01:13 PM
Jet Black
13
Dec 26, 2003 12:52 PM
Witty
Jul 2, 2003 09:42 PM
Black HB
Nov 14, 2002 04:22 PM
