What Is This On The Back Of My Manifold?
Old Jul 17, 2003 | 03:09 PM
LudeyKrus's Avatar
Default What Is This On The Back Of My Manifold?
On the back side of the throttle body/intake manifold, there's a black plastic covering w/ a wire wound coil thing inside of it. It is on the opposite side of where the throttle cable connects to the TB. What is this?
Old Jul 17, 2003 | 03:34 PM
Fly1865's Avatar
Default Re: What Is This On The Back Of My Manifold? (LudeyKrus)
TPS sensor
Old Jul 17, 2003 | 05:27 PM
machine4321's Avatar
yup throttle position sensor
Old Jul 17, 2003 | 06:16 PM
LudeyKrus's Avatar
Default Re: (machine4321)
Cool, thanks;
Is there anything special I need to know before I try to replace it?
Old Jul 17, 2003 | 07:31 PM
TimeRacer's Avatar
Default Re: (LudeyKrus)
Take the voltages from it first since this thing is VERY sensitive to being out of position.
Old Jul 18, 2003 | 03:19 AM
LudeyKrus's Avatar
Default Re: (TimeRacer)
From searching, the JDM H22's TPS's were adjustable.
So how do I make sure the new one, prob. from my H23, is positioned right? And if not, is there any way to move/adjust it to be right?
Old Jul 19, 2003 | 09:44 AM
LudeyKrus's Avatar
bizump
Old Jul 19, 2003 | 09:59 AM
Fly1865's Avatar
I replaced mine and it was easy. it only goes on one way.
Old Jul 19, 2003 | 10:57 AM
LudeyKrus's Avatar
Default Re: What Is This On The Back Of My Manifold? (Fly1865)
so I shouldn't have to do any adjusting?
Old Jul 19, 2003 | 01:40 PM
Fly1865's Avatar
nope
Old Jul 19, 2003 | 01:42 PM
sik96prelude's Avatar
how do you remove the TPS, isn't it rivited in there? How did you replace it?
Old Jul 19, 2003 | 02:19 PM
LudeyKrus's Avatar
Default Re: (sik96prelude)
you take a dremel w/ a cutting disk and cut a set of slots in their faces like a screw, then screw them out w/a screwdriver
DerekHollister
Mar 25, 2016 04:42 PM
prelude_93vtec
Jun 3, 2007 08:23 AM
cazper8890
Mar 2, 2007 08:25 PM
redintegra1998
Jul 14, 2005 10:43 AM
