Tps sensor calibration
Old Mar 24, 2016 | 05:11 PM
DerekHollister's Avatar
Default Tps sensor calibration
Hey there having a issue calibrating my tps I do not have the throttle cabke hooked up. It's a 68mm skunk2 throttle body I've tried 3 different tps sensor and at close I got a max of .2v to around 80mv. Can't get anywhere near .45. I installed the tab on tps inside the 2 tabs on the throttle body and rotated it counter clock wise to align screw holes.
Old Mar 24, 2016 | 05:33 PM
motoxxxman's Avatar
Default Re: Tps sensor calibration
remove the screws holding the tps to the TB and turn it til it reaches 0.45v, then look to see how far past the TB holes the sensor is to see if theres any chance of it lining up
Old Mar 25, 2016 | 02:05 AM
I've done that. It wount bolt down its gets to .45 .5 when the leg passes the mounting hole. But idk if it's because the thorttle body doesn't have the cable hooked up so the thorttle body is littearly shut not even open a. Tiny but but it idles fine without it hooked up. So ya pretty lost. I tried 2 new ones from oreilys and a used oem one all read the same
Old Mar 25, 2016 | 10:24 AM
motoxxxman's Avatar
sounds to me like a defective throttlebody
Old Mar 25, 2016 | 04:42 PM
I got it calibrated had to hook up the throttle cable
oz`Vtec
Feb 18, 2005 03:51 AM
GSRcivicGSR
Dec 20, 2004 04:29 AM
GsRwHiTe
Mar 22, 2004 03:08 PM
Redsim
Jun 11, 2003 09:37 PM
Inaniac
Oct 21, 2002 12:34 AM
