TPS sensor removal
Old Jul 14, 2005 | 06:49 AM
redintegra1998's Avatar
Default TPS sensor removal
It looks like the screws are messed up but upon further investigation I found its like that on all hondas. So, is there any specific way you are supposed to take the TPS sensor off of the intake manifold? It also a skunk2 intake manifold if that matters. Thanks.
Old Jul 14, 2005 | 08:31 AM
pubestripe's Avatar
Default Re: TPS sensor removal (redintegra1998)
are you sure that you are talking about the TPS sensor? the TPS sensor has two rivets that i had to drill out, then when i re-installed it, i just used to screws.
Old Jul 14, 2005 | 08:35 AM
Default Re: TPS sensor removal (pubestripe)
Yeah its the sensor on the back of the manifold. They might be rivets i can't even see them very well. I guess ill have to take off the manifold to get to them. thanks.
Old Jul 14, 2005 | 08:39 AM
Sack Master's Avatar
The sensor on the back of the manifold is the IAC. It's just bolted on. The TPS has rivets on it and it's on the back of the throttle body. So presuming you are talking about the TPS then you don't have to remove the manifold. Just the throttle body.
Old Jul 14, 2005 | 08:43 AM
Default Re: TPS sensor removal (Sack Master)
AHHHHH!!! GOD BLESS YOU GOOD SIR!! That is the info i've needed!!! sorry I don't know terribly much about cars as you can see. Thanks though.
Old Jul 14, 2005 | 10:43 AM
pubestripe's Avatar
thats how u learn!!!
JDM346
May 7, 2013 03:08 PM
zaxfire69
May 19, 2008 01:27 PM
90ZCREX
Sep 27, 2005 10:33 AM
shuttle xer
Jun 3, 2005 10:35 AM
cbabyby
Mar 18, 2005 03:38 PM
