pwd door lock/unlock wires in 95 del sol
Old Jul 17, 2003 | 01:10 PM
bearboy80's Avatar
Default pwd door lock/unlock wires in 95 del sol
I just installed my alarm and everything works except lock and unlock function.
I used Green/White for lock and Green/Red for unlock and connected directly to the wires from alarm main unit.
and this is where i splice the wires.(circled with blue pen)
are these right wires and right location to connect?
Old Jul 17, 2003 | 08:36 PM
bearboy80's Avatar
Default Re: pwd door lock/unlock wires in 95 del sol (bearboy80)
noone had installed alarm by themselves?
Old Jul 17, 2003 | 09:24 PM
Simple's Avatar
id like to know why in the hell my doolocks on my civic dont work, there is power to everything, they just dont unlock or lock
Old Jul 21, 2003 | 11:12 PM
Esoterikos's Avatar
Default Re: pwd door lock/unlock wires in 95 del sol (Simple)
i know that you shouldn't use those quick-connect thingy...the guy that does all the alarm installs for my shop solders everything, and yelled at me when i attempted to put my alarm in and used those things...says they are very bad...can cause fires. wait, that's what those little fire extingiushers are for, isn't it?
Old Jul 21, 2003 | 11:49 PM
salbaje's Avatar
check your alarm brain and make sure the toggle for that option is on
Old Jul 22, 2003 | 07:23 AM
EG-cellent's Avatar
Default Re: pwd door lock/unlock wires in 95 del sol (salbaje)
Should be white with black stripe(+)
green with red stripe(-)
Under dash behind the cruise module.
Old Jul 22, 2003 | 09:27 AM
bearboy80's Avatar
Default Re: pwd door lock/unlock wires in 95 del sol (EG-cellent)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG-cellent &raquo;</TD></TR><TR><TD CLASS="quote">Should be white with black stripe(+)
Under dash behind the cruise module.</TD></TR></TABLE>
+ is white/black? i checked the12volt.com and bulldogsecurity.com and they both say Green/White (-), Door Unlock Green/Red (-) and honda used - wires. not +. can you double check? thanks
Old Jul 22, 2003 | 06:38 PM
EG-cellent's Avatar
I will check in the morning when I get back to work. O.K.
Old Jul 23, 2003 | 09:01 AM
EG-cellent's Avatar
I checked and you were right on the colors and polarity.
on me,one of our books was wrong and the other 2 had the same colors as you did.
I would check to see if it is part of the programing.
Old Jun 6, 2015 | 10:59 PM
lurice01's Avatar
10 Year Member
Loved
Community Favorite
hey can you re-up that picture, its not coming up. I need to see where you spliced the wires. I can't find the door open trigger wires, or the door unlock and lock wires. If you or anyone could highlight those for me somehow, it would be great.
95 Civic 2dr coupe
Old Jun 7, 2015 | 11:13 AM
NotARaCist's Avatar
I never narc'd on nobody!
12 year old thread.
12 year old thread.
You've already been told by a moderator once. Stop bumping ancient threads. You've been around long enough that you should know better. If you have a direct question for a member, send them a PM. This guy hasn't even logged in in over 2 years - what makes you think he's going to magically show up just for you?
Old Jun 7, 2015 | 12:54 PM
Former User's Avatar
95 Civic 2dr coupe
Again, please create your own thread rather than bump ancient ones. See the forum Rules.
B-Rabbit20
Audio / Security / Video
40
Aug 21, 2015 10:53 AM
Clean98EJ8
Feb 6, 2015 07:54 PM
wolf95
Feb 2, 2010 02:29 PM
91sihatch
Apr 11, 2009 08:39 AM
sparta904
Aug 27, 2005 09:38 PM
