Whats a decent turbo for a stock b20?
Old Jul 16, 2003 | 06:53 AM
Will Albers's Avatar
Default Whats a decent turbo for a stock b20?
Im running an intercooled greddy turbo kit right now and i was curious if there is something better out there? Id like it to reach full boost faster. Right now its at about 4k rpms.
I run about 10 psi, i may build it up to run about 15, but thats about it. Any suggestions?
Old Jul 22, 2003 | 06:01 PM
thid92's Avatar
can I haz?
try a 3 inch exhaust
Old Jul 22, 2003 | 07:42 PM
b16ahybrid's Avatar
Default Re: Whats a decent turbo for a stock b20? (Will Albers)
Unless you swap to a bb turbo your going to hit peak boost later as you go larger on the turbo.
4k seems pretty decent to me, I hit full boost at about 5k rpm
Old Jul 22, 2003 | 08:32 PM
mos's Avatar
mos
Default Re: Whats a decent turbo for a stock b20? (b16ahybrid)
Does your wastegate open gradually as you reach your set pressure, or does stay completely shut until then?
Old Jul 29, 2003 | 05:03 PM
jdm4life's Avatar
I have a JDM B20B put in by Inline Pro in VA......everything is stock but the intake and custom 2.5 inch exhaust....oh and ACT clutch...I was thinking of putting in a turbo kit in my stock motor. I want to know if you have any problems at all w/ ur setup. ANd do you have any times at the track? Also are u running all stock internals?
Old Jul 29, 2003 | 05:22 PM
thid92's Avatar
can I haz?
Default Re: Whats a decent turbo for a stock b20? (jdm4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm4life &raquo;</TD></TR><TR><TD CLASS="quote">I have a JDM B20B put in by Inline Pro in VA......everything is stock but the intake and custom 2.5 inch exhaust....oh and ACT clutch...I was thinking of putting in a turbo kit in my stock motor. I want to know if you have any problems at all w/ ur setup. ANd do you have any times at the track? Also are u running all stock internals?</TD></TR></TABLE>dont even waste ur time boosting on stock internals. it will cost you alot more in the long run than doing it the right way
bigsnorlax
Mar 11, 2013 09:13 AM
94Eg_SnatchBack
Oct 25, 2011 12:41 PM
eghatch16
Nov 2, 2006 04:55 AM
EJ8boosted
Dec 23, 2005 07:49 PM
Ef-er
Jul 1, 2004 02:46 PM
