Starter
Old Jul 16, 2003 | 02:01 AM
Jowee's Avatar
Default Starter
I think my starter in the R is going out and I have no money to replace it. Is there anyway I can fix this without spending a lot of money???
Old Jul 16, 2003 | 06:18 AM
JimBlake's Avatar
Default Re: Starter (ITR 98 1162)
Depends on what's really wrong with it, & I can't see it from here... Exactly what's it doing wrong?
Maybe the solenoid just needs to have its contacts cleaned. Just your own labor.
Maybe the brushes are worn down. If you can find replacements, they'll be cheap & you provide the free labor.
Maybe you've got some corroded connections outside the starter? That's even easier.
Old Jul 16, 2003 | 02:22 PM
Jowee's Avatar
Default Re: Starter (JimBlake)
It makes wierd noises on a cold start then sometimes grinds. I'll try to take some pics after I get it off.
Old Jul 17, 2003 | 03:36 AM
JimBlake's Avatar
Sounds like maybe the pinion gear (or the ring gear) has some mashed teeth?
Old Jul 17, 2003 | 09:05 PM
Jowee's Avatar
Today my starter didn't work. Then my friend told me to tap on the smaller cylinder thing on it a few times and now its acting like it never had the problem b4 right after I bought a starter . Any ideas?
Old Jul 18, 2003 | 12:38 AM
ryanstev's Avatar
Dust in the solenoid.
Hitting it with a hammer displaces the dust and allows the soldenoid to hit two contacts inside, which sends power to the starter.
If you want you can take the solenoid apart and give it a clean.
Old Jul 22, 2003 | 02:21 AM
Jowee's Avatar
Default Re: Starter (ryanstev)
It works perfectly fine now, but I think I shall take it apart and clean it. Thanks a lot guys .
HokieS2K
Honda S2000
Feb 16, 2009 05:02 PM
dominate9
Jan 16, 2009 04:32 AM
M1SCO15
Feb 19, 2008 04:51 PM
WTB AUTO EK
May 12, 2005 06:46 AM
gliaw
Nov 21, 2002 02:53 PM
