mini-me swap, need to wire vtec...
got a 95 dx hatch with an si head, and the vtec is currently wired through the shift light so when the light goes on, it activates the vtec. The car came with a P28. dont know the first thing about wiring, so i just wanted to know if someone could tell me how to wire the vtec correctly so i can stop with this ghetto shift light ****. Thanky.
VTEC wiring is faily simple. It's three wires.
First locate the VTEC solenoid (1 wire) and the VTEC oil pressure sensor (2 wires).
Simply take the Grn/Yel wire from the VTEC solenoid on the engine harness, and lead that to the A4 pinout at the ECU.
For the VTEC oil pressure switch, take the Blu/Blk wire from the VTEC oil pressure, then leads to a ORG/BLU wire, lead that to the D6 pinout.
As for the BLK wire, lead that to the thermostat ground.
05 S2K Stoner
Oct 28, 2004 06:40 AM
