Do 92 Civics have a headlight on warning chime?
Thanks tons. And to think, I was going to wire this up myself even if there wasn't a thread about it already.
I wrote that initial thread you found.
That other means doesn't work like most cars, where the buzzer goes on only if you open the door. It goes on if the car is off and the lights are on, period.
Depends on how you want to do it.
I have pretty extensive knowledge of relays, and am probably going to use the factory honda "Morse code" for my headlight warning. I just snatched 2 relays out of the back of work and plan on doing this tonight. Thanks for the help.
u only need 1 relay. just hook up the coil to the "D" accessory terminal on the fuseblock. i'm not sure if it's labeled, it should be the 4th one.
then hook up the switch of the relay to ground and the other side goes to one of the lines on the ignition switch. i can't remember which one it was. as soon as i find it i'll post here. basically you're tricking the car to think u left the keys in the ignition switch.
sageuvagony
Oct 4, 2008 09:07 PM
HondaJack
Aug 22, 2006 07:19 AM
