I am going LS..
Old Jul 15, 2003 | 10:13 AM
JDM CTR EK's Avatar
Default I am going LS..
I want to do an LS motor swap into my EK. Can anyone help me and tell me everything that i need please.
Old Jul 15, 2003 | 10:21 AM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
- Motor
- Hydrolic Tranny (Y80, S80)
- ECU (P75)
- Axles
- Shift Linkage
- Wiring Harness
- Mounts?
Might want to pick up a new water pump and timing belt while you got the motor out. Plus plugs/wires and fluids.
Old Jul 15, 2003 | 10:23 AM
SjCiViCHB's Avatar
Default Re: (1 point 6)
youll need mounts from an SI
Old Jul 15, 2003 | 11:40 AM
JDM CTR EK's Avatar
- Motor
- ECU (P75)
- Axles
- Shift Linkage
- Wiring Harness
- Mounts from an SI
That's all I need? Then I am good to go for install..
Old Jul 15, 2003 | 11:45 AM
allmtr's Avatar
Default Re: (JDM CTR EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM CTR EK &raquo;</TD></TR><TR><TD CLASS="quote">- Motor
- ECU (P75)
- Axles
- Shift Linkage
- Wiring Harness
- Mounts from an SI
That's all I need? Then I am good to go for install.. </TD></TR></TABLE>
u can use a y21 tranny too
and u only need the si or gsr rear tranny mount. i like the gsr mount better cuz it sits slightly lower.
Old Jul 15, 2003 | 11:50 AM
JDM CTR EK's Avatar
Default Re: (allmtr)
should I go with an SI Tranny and a GSR Mount?
Old Jul 15, 2003 | 11:52 AM
allmtr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM CTR EK &raquo;</TD></TR><TR><TD CLASS="quote">should I go with an SI Tranny and a GSR Mount?</TD></TR></TABLE>
thats what im using and i got no complaints
Old Jul 15, 2003 | 11:56 AM
WongFeihung's Avatar
thats what im using and i got no complaints [/QUOTE]
you using the si or GsR's?
Old Jul 15, 2003 | 12:12 PM
allmtr's Avatar
Default Re: (WongFeihung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WongFeihung &raquo;</TD></TR><TR><TD CLASS="quote">
you using the si or GsR's?</TD></TR></TABLE>
gsr mount
Bloody Hatch
Jun 28, 2012 01:39 AM
4serioferio
21
Jan 29, 2010 01:33 PM
liquidx
Aug 7, 2007 06:20 PM
mystikalG
Aug 10, 2006 06:41 PM
90civichbsi
12
Jun 26, 2002 11:21 PM
