is it easy to replace wheel stud?
Old Jul 14, 2003 | 09:52 PM
_Endless_'s Avatar
Default is it easy to replace wheel stud?
one of the wheel stud of my 2000 SiR is damaged and i already bought a new stud. a shop told me that the old stud should be pressed out by a machine shop, is this true? can it be a DIY?
Old Jul 15, 2003 | 12:15 AM
inFamousOneSix's Avatar
Default Re: is it easy to replace wheel stud? (_Endless_)
its an easy diy job. remove wheel, etc to expose the hub and knock it out with a hammer, then insert the new stud and torque the lugnut onto it w/o wheel to seat the stud.
Old Jul 15, 2003 | 08:50 AM
94CivicSi's Avatar
Default Re: is it easy to replace wheel stud? (inFamousOneSix)
I wouldn't say it's easy. I don't know about EK's, but on my EG there is a slight recess at the 6 o'clock position on the knuckle. Turn the hub until the broken stud is at the 6 o'clock postion, then hammer it out. You'll have to remove the dust sheild first.
The new stud goes in the same way, but since it's longer, you'll find it more difficult. Just take your time and be patient. If you start beating and banging the thing in, you'll damage the threads.
Old Jul 15, 2003 | 09:45 AM
martini's Avatar
it can totally be a DIY. but it would help to know if this is the front or back.
Old Jul 15, 2003 | 07:45 PM
_Endless_'s Avatar
Default Re: is it easy to replace wheel stud? (martini)
the damage stud is in the front passenger side. the stud is not broken but the thread is stripped and i don't know what caused it.
christiantequila
Dec 22, 2008 08:11 AM
dre2day
Feb 16, 2008 07:56 AM
pinoyboy204
Apr 13, 2007 01:53 PM
LudeyKrus
Jul 26, 2004 10:42 AM
dsb2695
Sep 23, 2003 11:09 AM
