is it necessary to remove spindle to replace a wheel stud??
Old Apr 10, 2007 | 10:21 AM
pinoyboy204's Avatar
Default is it necessary to remove spindle to replace a wheel stud??
as the title says. snapped a wheel stud a month ago and finally have some time this weekend to tackle it.
just wondering if i would need to remove the whole spindle or is there some sort of cheating way so i don't have to remove the entire unit.
let me know guys!
Old Apr 10, 2007 | 11:58 AM
Sam92Teg's Avatar
Default Re: is it necessary to remove spindle to replace a wheel stud?? (pinoyboy204)
Depends on the car and whether it is the front or rear wheel. If you jack up the car and pull the tire, you should be able to look behind the hub to see if there is a gap or space enough in the hub to pound out the stud and replace.
Old Apr 10, 2007 | 12:04 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: is it necessary to remove spindle to replace a wheel stud?? (Sam92Teg)
yes you will need to pull the spindle to be able to properly install a new wheel stud.
Old Apr 11, 2007 | 12:09 PM
Default Re: is it necessary to remove spindle to replace a wheel stud?? (coptzer)
yea, this is for the front drivers side.
a friend of mine said you could probably grind a little bit of the end of the stud to make it go in easier...any truth to this?
Old Apr 12, 2007 | 03:59 PM
00civicsiboy's Avatar
So on the front axles, it is possible to replace a wheel stud by simply tapping it out from the back?
BTW sorry to thread jack
Old Apr 12, 2007 | 05:26 PM
schardbody's Avatar
you do tap it out the back, only problem is there isnt enough room to tap it out the back of the hub with the hub still pressed into the spindle.
so yes, you have to remove the spindle in order to press the hub out in order to remove the stud.
or do like i do and grind the spindle to allow clearance of the stud. (ghetto, only for customer cars, not mine)
Old Apr 12, 2007 | 06:45 PM
Default Re: (schardbody)
So in order to preserve the bearings, I need a press to slide it out?
Old Apr 12, 2007 | 06:48 PM
Default Re: (00civicsiboy)
yes
Old Apr 12, 2007 | 06:52 PM
Default Re: (coptzer)
Do you think autozone or anyone of the auto places carry one that I could borrow?
Old Apr 13, 2007 | 01:53 PM
schardbody's Avatar
it doesnt exactly slide out, but yeah, it has to be pressed out, then pressed back in.
or you could pay a shop $40-50 to do it.
dre2day
Feb 16, 2008 07:56 AM
integraRS-T
Nov 15, 2007 11:17 PM
Pompiuses
Sep 12, 2005 06:57 AM
LudeyKrus
Jul 26, 2004 10:42 AM
mr2turbo
Mar 1, 2004 09:19 AM
