new 03 si break in: fuel question
Old Jul 14, 2003 | 02:50 PM
jdmillusion's Avatar
Default new 03 si break in: fuel question
ok. one thing that confuses me is fuel choice. my friend just told me that, when breaking in new cars, it is necessary to use a high octane fuel (ie. 91+). is this true? he also says, if i don't do so, after 50k mi. or so, there might be a higher chance of me getting detonation. any input regarding this fact or fiction heresay would be appreciated. thanx again h-t.
Old Jul 14, 2003 | 03:52 PM
Draco's Avatar
Default Re: new 03 si break in: fuel question (jdmillusion)
Just use whatever gas is recommended by the user manual, which should just be the lowest octane rating that will avoid knock, which is bad no matter how new the engine is.
Old Jul 16, 2003 | 07:39 AM
Default Re: new 03 si break in: fuel question (Draco)
wait, so it doesn't matter what octane rating you'd use in a new engine? it'll still knock?... so there's no way to avoid it?...
Old Jul 18, 2003 | 10:13 PM
Draco's Avatar
No, greater octane will prevent knock, but for instance if the car won't detonate on 91 octane then it's pointless to use 93. Also, using too high of an octane could hurt your engine by not letting it combust efficiently, but that's not nearly as bad as detonation. Plus, its cheaper.
Old Jul 19, 2003 | 02:23 AM
EFb18b's Avatar
The compression ratio in the new si isn't high enough to worry about knock with 87 octane thats why honda doesn't haven't recommended that you use 91+. If you use 87 it'll be fine.
Old Jul 19, 2003 | 09:07 PM
Mr. Choi's Avatar
New User
your friend is a dumbass. use whatever gas its asking for, i htink 87.
Type-Stuner
Acura TSX
28
Jun 21, 2010 05:27 AM
EGed up from the seat up
Engine Management and Tuning
Mar 4, 2009 03:38 AM
kahriak
Acura TSX
Feb 10, 2008 12:45 PM
Cvicex609
Honda Civic (2006 - 2015)
17
Dec 2, 2007 03:30 AM
teg your it
Apr 23, 2005 02:06 PM
